question for general discussion regarding: bi-wiring
aps1ngh
Do you think those people that hear an audible difference from bi-wiring are really just hearing the difference from removing their low quality jumper and replacing it with an extra set of high quality wire?
Discuss.
Discuss.
Post edited by aps1ngh on
Not in my case (tho I think I 'bi-AMPed' - I'm still confused about difference as definitions vary), I didn't screw around with any wires, just:
1. removed jumper bars on speakers
2. used surround back channel terminals - to speakers' extra terminals.
My sense is that this really only improves sound in certain situations (it did in mine - Onkyo 705 - RTi10's) YMMV.
It's certainly a cheap easy upgrade, and if you don't like the results. just undo them.
HOWEVER: IF you have the bucks and space - my sense from reading these boards - is that a dedicated amp is the way to go.LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
