SACD 5-disk Player Recc's pleaas
xandra
Am toying with the idea of getting a 5-disc SACD DVD Player, so far the one that sounds best to me is the Denon DVM-2845CI
http://www.crutchfield.com/App/Product/Item/Main.aspx?search=Denon+DVM%2D2845CI&i=033DVM2845
has anyone seen/tried this?
how testy is it to get SACDs to play at full res if reciever doesn't specifically support (as near as I can tell browsing the manuals, you have to use multichannel to play)
One concern with this unit is that it's still HDMI 1.1 - (my other stuff is v1.3) Is this likely to be a compatability issue?, the only feature of v1.3 I'd be concerned about losing is lip sync adjust - which may or may not be an issue.
Anyone else have a similar unit.
I'd also considered Sony's 400 disc player, but I understand it looses it's memory in a power outage...
http://www.crutchfield.com/App/Product/Item/Main.aspx?i=158CX995V&search=SACD+DVD&tp=170
Comments please.
Comments please.
LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
You can go check out the Sony SCD-CE595 5 disc SACD/CD changer ($150.00) at your local Best Buy. It sounds very good with both CD and SACD, but it's kinda slow in loading and recognizing what type of disc it's playing.
You can play SACD in 2 channel stereo using just your regular analog inputs of your receiver. SACD is a 2 channel format from the very beginning and multi-channel surround sound was added later on to compete with DVD-A. You will get full resolution whether using the analog outputs or HDMI v1.2 or above (assuming your receiver can decode DSD).
Going beyond the Sony, the next rung up the ladder wlll be Sony ES, Marantz, and Yamaha. -
any of the Sony ES stuff is really good: SCD-C2000ES, SCD-C222ES, SCD-C333ES, etc.
I would check them out on audiogon, etc. I had the first two and really liked them both.
If you are okay with single disc, I have a PE 45AV that works awesomely well for 2-channel. If you decide you want to upgrade down the road, get a decent DAC for a couple hundred bucks and you're set.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
Danny Tse wrote:You will get full resolution whether using the analog outputs or HDMI v1.2 or above (assuming your receiver can decode DSD)
My manual says: DSD sources are converted and handled as PCM
Does this mean it decodes DSD, or prostitutes it?LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
I'm very partial to the one below as I own and it's a little costly but well worth the price.
Yamaha DVD-C961 Black Multi Disc DVD Changer
5-Disc DVD-Audio / Super Audio CD ChangerTV - TOSHIBA 47LZ196
FRONTS - RTI10'S
CENTER - CSI5
SUB - PSW 404
SURROUND - RC8OI
AV RECEIVER - ONKYO TXSR 804B
HDDVD - TOSHIBA HDA2
SACD/CD/DVD CHANGER - YAMAHA DVC6770 -
fbwinners wrote:I'm very partial to [Yamaha DVD-C961] as I own and it's a little costly but well worth the price
I took a look at this - sounds like an excellent reccomendation (was glad to see it does CD-Text since I've burn't many of these)
fb:
How do you have this connected to your Onkyo?
Have you tried with SACD's, DVD-Audio : do you use HDMI, Multichannel, or Dig audio when playing these...?
Have you had any HDMI issues?
in reading about it at crutchfield i noticed the following:
"SACD audio output via HDMI"
then...
"The audio portion of the HDMI output must be turned off if you're using the optical or coaxial digital output. If the HDMI audio output is turned on, the optical and coaxial digital outputs are muted."LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
