Denon Avr 3805
mhartman29
Does anyone have an experience with this receiver? I might be able to pick one up at a decent price, so I'm curious if anyone has any thoughts on the receiver.
I'd be replacing my Onkyo TX-SR603X. Would that be a good step up? Or more of a lateral move?
Thanks!
Thanks!
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
i've never been much of an Onkyo fan.. sorry. so I'd say go with the Denon AVR 3805 if you can get it for a decent price.PolkFest 2012, who's going>?
You will love the Denon. I had a Onkyo then switched to my present receiver.
engtazengtaz
Denon or HK are the way to go, imho. They sound better, are normally built like tanks, and most of their lineup can handle 4 ohm loads without any major drama.
Just remember to get a model that has pre-outs for all channels. All but the smallest HK has them."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
I had one....liked it alot. It wasn't too great for two channel so i put a Rotel amp with it and it was a great combo. You will want to make sure you have rechargable batteries for that remote though...it eats them for breakfast.Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W -
I have the 3805 as well, and for movies, it's the cats ****. Two channel however is sub-par IMOP"she had the body of Venus, with arms."
Actually, Denon reworked their receivers starting with the 3805. For a muti-channel receiver, it was probably the best sounding in two channel mode of any Denon for a decade before it. It's not bad sounding at all, getting rid of the midrange congestion and rolled off HF that used to be called "smooth", but was to my ears just nasal and rolled off. Annoying on a good pair of speakers, but would tame a set of cheesy tweeters.
In the big picture of Japanese surround receivers, the 3805 is actually pretty far up the food chain. The updates applied by Denon made a HUGE improvement in overall sound quality.
MarkSystem:
VPI Scout/Benz Ace
Sutherland PH2000
Arcam CD72
Yamaha DVD-CX1 (primarily for CD..26 lbs, all BB D/A)
Audioprism Mantissa w/Reference PS
Parasound HCA750 (temporary)
Audiovector M1 Signatures
Kimber 4TC x 2 -
The nice thing about the new crop of Denons is that they support HDMI 1.3a and 1080p, so if you get a new Denon and you upgrade your TV or projector and it also has 1080p and HDMI 1.3a then you know they are going to be working well together from a video point of view. The new Denons, pretty much the whole line-up, I think but verify, also support the new codecs for sound such as DTS. So you should e set for a few years without needing any upgrades.
I think the new Denon is the 3808CI that might comprare to the 3805. Depending on your Video setup the 3805 wil do well for you, but if your have 1080p and HDMI 1.3a you would be better with the newer Denons, although I have read many video forum posts stating you have to do a firmware download on the 3808CI and it is not always successful. At this point I'd almost wait until the next version if I went with a new one.Speakers: LSi15 front
Integrated amplifier: NAD 320BEE
Furman PL Plus Series II (line conditioner)
HD DVD A35 Toshiba (Sloooooowwwww to start)
Oppo HD981 (Nice unit) -
I use my 3803 mostly for movies and I love it. With the upgrades in the 05, I think you will be more than happy.Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
