Speaker matching help (please)
Looking at purchasing RC85i in-wall speakers for fronts, CS1 center and FXi3 for rear surrounds. Will this be a decent set up? My concern is that the
FXi3's literature states they are matched to the RTi series. Can anyone tell me if they will work well with the RC85i's (which say they are best timbre-matched to the RM series)? Maybe I should just give up on the FXi3's and put RC65i's in for rear surrounds instead? I just really, really like the FXi3's!
Thanks,
Dave
Thanks,
Dave
Forgot to mention a PSW10 sub will be used with the system as well.
