Signal Cable 3ft Magic Power powercord
phipiper10
phipiper10 Posts: 961
edited December 2007 in For Sale (FS) Classifieds
Hi Guys,
I recently rearranged my cabinet and my amp is no longer within 3' of the line conditioner.
This was $64 shipped from Signal after the Polk discount earlier this year.
It's yours for $40 - free shipping.
From Signal:
10 AWG 3 conductor twisted design
High purity stranded copper for maximum conductivity
Premium grade jacket provides excellent resistance to abrasion, water, oil
UL listed and CSA certified
Temperature range: -40ø C to +90ø C
Voltage rating: 300-600 volts
Max. Amps @ 120V: 30A
This reference Power Cord is based on a 3 x 10AWG twisted design terminated with ultra high quality Marinco HG connectors. Unmatched frequency extension and detail retrieval as well as an improved soundstage and blacker background. Starting at less than $60, this is a tremendous value in high end audio!
Application: Power Amplifiers, Powered Subwoofers, Analog Preamplifiers and Power Conditioners
I'm holding onto my MagicPower Digital Reference cable which is hooked up to my cdp :)
Paypal preferred - PM me.
Thanks,
Rich
Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Post edited by phipiper10 on
  • phipiper10
    edited November 2007
    Here is a pic from Signal...it's exactly the same.
  • beardog03
    beardog03 Posts: 5,550
    I`ll take it..
    Pm sent
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • beardog03
    done
    payment sent
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • phipiper10
    Sold to beardog!
  • beardog03
    cool !
    I just wish I would have grabbed those bi-wires...
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • dorokusai
    dorokusai Posts: 25,625
    That's as much power cord as you'll ever need. Everything else is just hype.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    My PC of choice. Use it. Love it. Make love to it.
  • beardog03
    It`s the same one that i got from you, yes/no ?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • RuSsMaN
    Yes. Like an idiot, I ended up with a surplus somehow, now I need a couple more again. ;)
    Doesn't matter, I'm happy to order new from Frank, the dude rocks, and supports Club Polk.
  • beardog03
    Agreed...
    He has been a CP supporter for some time now, and is always willing to help a CP member
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • daboyz
    daboyz Posts: 5,207
    Damn,watch the Cowboy game and miss something............
  • SolidSqual
    SolidSqual Posts: 5,218
    I just bought a Magic Power Cord for my Odyssey. Its addition was a really noticeable difference. It actually made my amp sound more musical. I'm not sure if it did something to the highs the mids or the lows, but the addition just felt better on my ears. Removing the cord, I immediately could tell the difference. My girlfriend could even hear a difference . . . that's the ultimate test in my book! Just bought a digital one for my Azur 840C. SC rocks!
  • dorokusai
    Sweet.
  • avguytx
    avguytx Posts: 1,628
    I'd almost buy a power cable like that to try but the only piece of gear I have with an IEC plug is a Magnavox console tube amp I rebuilt. Damnit. The Carver amps are all hardwired like most all the older stuff and it's not worth it on my HT stuff as I don't have anything major. Ok, the Sunfire sub has an IEC plug...forgot about that.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • beardog03
    it would make a great sub cable
    you should give Frank a call...Money well spent , IMO
    for about the price of a cheap hooker, you could be feeding your sub the right way..!!
    ***Lord forgive, and be with the starvin pigmees in New Gunie***
    Larry The Cable Guy
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • RuSsMaN
    If you can tweak that old tube amp, you can add an IEC to pretty much anything.
    treitz3 Posts: 20,239
    Kip, you'll love the result on the sub. ;)
  • avguytx
    I'll have to wait till I get the living room wall redone and pick one up. I spent most all day yesterday tearing down the wall I had built 3.5 years ago based around a 56" Panasonic RPTV. I bought a plasma a few weeks ago and will be wall mounting it. So, the huge beast came down and I have to do some painting, cut the holes for the 3 new LCR's, mount the bracket, paint the LCR's, wire the new wall plate, etc, etc. It'll be a few weekends of projects but ultimately, I'll have a separate 7.1 system (all in-wall/in-ceiling speakers) and the ability to finally get my Carver gear and SRS II's in the living room, or, the tube amp and Altecs, or whatever else I want to rotate.
    Once I get the room done for the most part, I'm going to do the old trick and sit the sub on the couch and listen around the living room and see where it's "hot spot" is so I'll know where to drop the signal cable to it and hope that there is an outlet close by. If not, I'll have my neighbor, the electrician, wire me an outlet where it needs to go. Then I can finally get a power cord and see what happens. Yeah, a lot of crap to get done and here I sit.
  • avguytx
    RuSsMaN wrote: »
    The worst part about wiring that IEC connector on that old amp was cutting thru that thick metal and then all the filing to get it down to size. Ultimately, it worked out pretty good, I think. Definitely sounds nice and is easy to move around!
  • beardog03
    Recieved the cable yesterday...
    Thank you very much....flawless transaction
    Cable is in perfect condition !
    Thank you very much
    I will leave feedback post haste
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
