Polk Lsi 15 ( Stuffing ports )
Tropicalpests
Tropicalpests Posts: 4
edited November 2007 in Speakers
I'm new to this forum and have done some reading on some of the posts on stuffing the ports to beef up up the lower end of the Lsi 15. I too think the bottom end is a little muddy and could be somewhat punchier, I'd like to try stuffing the ports, but my question is what ports do we stuff and what is the best stuffing material to use?
Post edited by Tropicalpests on
  • john22614
    john22614 Posts: 214
    Two cups of cornbread, diced onions and celery, chicken broth and some sliced sausage....I have no idea, but welcome to the forum. Someone here will be able to help.
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Monitor Radius 180 surrounds
    Audiosource Stereo Amp for surrounds
    Denon 2910 Universal DVD/SACD Player
    Comcast DVR
    Pioneer Elite 42" Plasma 940 HD
    Harmony Universal Remote
    Blue Jeans interconnects and biwires
    Itunes Air Express
  • polkatese
    polkatese Posts: 6,767
    This has been tried by our port stuffing expert, Zero, I think. Where are you, Sean?
    Do your search, if I recalled, at least 3 years ago or so.
    Btw, welcome to CP.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • dorokusai
    dorokusai Posts: 25,576
    I was told that dampening the power port(tube) was more beneficial than stuffing the ports. I do this on all modern Polk's I have owned in my travels.
  • jakelm
    jakelm Posts: 4,081
    I stuff mine with Dacron or the inside of an old pillow. Did it to a couple of cheap subs, worked pretty well. Doesnt seal it, but dampens very well..
    Edit: Do the 15's have any type of internal dampening?
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • Frank Z
    Frank Z Posts: 5,860
    Stuffing anything into the ARC ports will ruin the sound of the LSi's. Anyone thatthinks they sound better like this is deaf and stupid.
  • jakelm
    jakelm Posts: 4,081
    Frank Z wrote: »
    DUUUUHHHHHH....What did you say???
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    VR3 Posts: 29,440
    ARC port and Power port are two different things
    ARC port is designed to reduce midbass emphasis, which if you plug that - i can see that ruining the sound
    Never tried plugging either port - so not sure
  • McLoki
    McLoki Posts: 5,231
    The port you stuff is the one in the bottom of the speaker. (facing down)
    I have not done it to mine, but may give it a shot. (I cross them over at 80hz anyway, so any bottom end lost will not be a big deal to me...)
    If you end up trying it, let us know what you think of the mod... (and welcome to Club Polk!!)
    Michael
  • Tropicalpests
    Well I tried it and I don't know if I like it!!?? The highs aren't as extented as before and the soundstage isn't as great and I have to give it more volume, but it did give it some punch and the muddy sound seems to be gone, but I think I'm going back to stock.
    Thanks for all the help!!!!!!
    Charlie
  • woofiepaws
    woofiepaws Posts: 223
    dorokusai wrote: »
    What do you damp them with?
  • Tropicalpests
    I went to the local craft store and bought foam rubber and cut strips and kind of worked it around up the power port, a little tricky getting it up and even. I did't like as it was to flat for me, but do you want hear somthing weird? The extra volume I used for a couple of hours loosened up the 8" woofer alot! Ok don't believe but it sounds much better!!!!!!! Try it let me know
    Charlie
  • dorokusai
    woofiepaws wrote: »
    I used weather proofing mastic to seal coaxial. Dynamat is the same thing, just not as thick and pretty. The mastic comes in non-descript brown cardboard, in a roll and it worked just fine.
  • scottnbnj
    scottnbnj Posts: 709
    tp, welcome to cp.
    have you tried repositioning the speakers and listening position? changing distances from nearby walls and reflective objects could change things a bit. bass traps might help too.
    if you aren't familiar with this stuff, google up strings like "room acoustics", "bass traps" and "speaker positioning".
    as far as break in after pushing them a bit, it's not weird at all. i noticed changes during break in with my lsi9's after driving them hard a few times.
