Will these work with the Polk Lsi?
Phasearray
http://www.madisound.com/catalog/product_info.php?products_id=1679
Seems so cheap if you ever need a new tweeter.
Receiver - Onkyo HT-R340
Front - Pioneer S-HF21
Center -Onkyo SKC-340C
Surround Back - Polk R15 <--Ticket to club polk
Subwoofer - Onkyo SKW-340
Post edited by Phasearray on
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=264-555
Nope -- But that ^^^ is an exact replacement!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=264-555
But does the parts express one fit inside the polk Lsi mounting bracket?Receiver - Onkyo HT-R340
Subwoofer - Onkyo SKW-340 -
its the same tweeter?
I dont understand??
Only difference is this one dosnt say Polk and cost half as much for you...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Hmmm
Wow I never noticed Polk cut off the top part of the mounting bracket --
Well, never mind - it is identicle though, if you were good with a router itd work like a charm- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Well --
I apologize...
Polk must of wanted those midbasses closer together!
Hmmm- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »Well --
I apologize...
Hmmm
Hah! In wonder if I can unscrew the 3 mounting bracket on the polk tweeter and the partsexpress tweeter then swap them in if my Lsi tweeter ever needs replacin. Problem is it uses these extra small 3 star shape head screws that I can't find an exact match tool for...
Maybe it's to prevent idiots like me from messing with it.Receiver - Onkyo HT-R340
I believe you can swap out the baffle plate.-Ignorance is strength -
