Confusing Amp terminology
xandra
xandra Posts: 291
Was looking into Emotive RPA-1 Amp
http://www.emotiva.com/rpa1.html
The web page reads:
Conservatively rated at 200 watts RMS per channel in a dual mono configuration, the RPA-1 is the perfect companion to the RSP-1.
then, later listed in the specs:
• 200 watts RMS per channel into eight ohms
Whad'they mean by dual mono configuration???
Is this really 200 watts per channel at 8 ohms or not?
LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
• 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
Post edited by xandra on
  • beardog03
    beardog03 Posts: 5,550
    edited November 2007
    dual mono means there is two seperate power supplies and that it has two seperate "mono" channels that work together to be one two channel amp
    It has two power cables , yes ?
    It`s like have two mono amps in one chassis
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • DollarDave
    DollarDave Posts: 2,575
  • beardog03
    Thanks Dave...
    I was tryin to splane, but...:rolleyes:
    sometimes not so good at splanin`
    :D
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
