RTi4 or FXi5
ok i purchased a set of FXi3s along with my CSi5 from crutchfield today, i planned on using the FX as surround and purchasing FXi5s from a member as my rears
i like to get the most from my movies/ with good sound but i also love to listen my music...so would i be disappointed in just purchasing RTi4s and using them as the surrounds and the FXi3 as rears or should i stick with my original plan of FX's all around?
Post edited by acsubie on
I had FXi5's as my side surrounds, and FXi3's as my rear surrounds in a 7.1 HT setup. I thought it sounded great! If you are going to listen to multi-channel music a significant amount of time, then you might consider the RTi4's for the side or rear surrounds.DKG999
