need more HDMI
ntculenuff
ntculenuff Posts: 1,146
edited November 2007 in Electronics
so any one here have any first hand knowladge on some of the HDMI switchers out there?
Half-**** looked up a few and found they range from 150-250. not wanting to get a new recvr/preamp just yet.
Speakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2
  • pearsall001
    pearsall001 Posts: 5,400
    ntculenuff wrote: »
    Is this what you're looking for? http://www.oppodigital.com/proddetail.asp?prod=HM31
  • ntculenuff
    yup pretty much. you know much about it?
    Speakers:
    Polk RT800i's rears
    Audio:
    Onkyo TX-NR3010
    Video:
    OPPO BDP-103 Bluray
    Directv x's 2
  • pearsall001
    ntculenuff wrote: »
    I can't comment on that particular Oppo product. What I can comment on is that Oppo makes great gear at prices others can't match. Reviews on their stuff seems to bear that out. I have one of their original players, the DV971H & it stiil performs great for both video & audio. I would not hesitate to buy another piece from Oppo.
  • nebborjk
    nebborjk Posts: 425
    I just installed a gefen 4X1 DVI switcher. Works great. I picked it up for $75 at videogon. It seems that DVI switchers are about half the cost of HDMI swichers. Since the two connectors pass the exact same video you may be able to go the dvi switcher route and use dvi to hdmi cables. Then again if everything you own is already hdmi this may cost more in new cable than it's worth.
    Proud SOPA Member since 2005!
  • Onac
    Onac Posts: 36
    have been using the Monoprice 4x1 switch with no issues at all. Hard to beat for just ~$40.
  • Sherardp
    Sherardp Posts: 8,038
    + 1 on the monoprice switches, excellent value.
  • ntculenuff
    kewl thanks..
    Speakers:
    Polk RT800i's rears
    Audio:
    Onkyo TX-NR3010
    Video:
    OPPO BDP-103 Bluray
    Directv x's 2
  • Sami
    Sami Posts: 4,634
    If they only took in 1.3 HDMI and would output 5.1 HD audio... :)
    I'll most likely pick up one when I upgrade to 1080p projector, instead of upgrading my preamp.
