Momo c500.1 with single SR124 DVC setup
jfeinman
Ok, just got my SR124 DVC sub and my momo c500.1 on accommodation from polk. My question is on the speaker wire hookup from the sub to the amp. The manual only mentions the connection of a single SVC at 4 ohms to the amp, or 2 SVC 4 ohm subs independently plugged into Sub 1 and Sub 2 to achieve a 2 ohm load.
Should I just connect it the same way as the SVC, as it just has it plugged into the "Sub 1"? Or should I do a bridged connection, over both sub 1 and 2? Or, should I run two sets of speaker wire from the sub to the amp; one voice coil to sub 1 and one voice coil to sub 2? My goal here, as you can guess, is to get a 2 Ohm load to the single sub, so I can get the full amount of power.
Post edited by jfeinman on
The sub is already wired in parallel. So just hook it up to the c500.1 for a 2ohm load. That'll give you 500 watts. I have that same setup and it sound great.
Thanks guys...ya just answered my question also..!!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
