Harman Kardon FL-8450 CD Player
BaggedLancer
BaggedLancer Posts: 6,371
SPECIFICATIONS:
Optical Readout System
Laser : Semiconductor AlGaAs
Wave Length : 760-800 nm
Numerical Aperture : 0.45
Signal Format
Sampling Frequency : 44.1kHz
D/A Conversion : Dual 1 Bit
Oversampling : 8 times
CD
Overall Diameter : 120mm/80mm
Width : 1.2mm
Speed : 500 - 200 rpm
Playing Time (theoretical) : 74 min. (stereo)
Track Pitch : 1.6um
General
Number Of Channels : 2
Frequency Range : 20 - 20kHz +/-0.2dB
Signal-to-Noise Ratio : More than 104dB
Dynamic Range : More than 94dB
Total Harmonic Distortion : Less than 0.005% @ 1kHz
Output Level : 2 Volts RMS
Power Supply : 120 v, 60Hz
Power Consumption : MAX.16 watts
$100 shipped Con. Us.
Comes with original paperwork, remote, audio cable. No original box, sorry. This unit is mint condition and plays great other than a small nick on the corner of the player. Has optical connection in back for Toslink cables.
Post edited by BaggedLancer on
