Low cost receiver for Polk Monitor 10Bs
nms
Hello all.
First post here.
I recently got hold of a pair of used Polk monitor 10Bs. I already know they're great speakers because my parents have a set, so I'm very happy to get a set of my own. I got them for free from a family member - please don't hate me ;-)
Anyway, now I'm looking for a receiver to power them. Polk rates them at no more than 125 wpc, and from personal experience I know they're plenty loud enough with about half that. I'm looking for a low cost (less than $300) no-frills receiver that will deliver a good clean signal.
USE: The speakers will be used in a dorm room for the first several years, so they will not see high power settings very often. The system will be used to play music only - no home theatre. Music types include classical, organ, rock, new age, pretty much a bit of everything but rap and country. They will be set up in stereo mode, so I'm trying to stay away from multi-channel receivers designed for 5.1 or 7.1 setups.
Again, I could care less about bells and whistles on the receiver, but I do care about clean power and good sound (I'm something of a closet audiophile). From what I've heard and read, the monitor 10s are pretty sensitive to a clean signal.
From a little bit of research, I've got the following as possibilities:
- Denon DRA-375RD
- Sherwood RX-4109
- Onkyo TX-8222
- Sherwood RX-5502
The Denon got pretty good reviews and seems to be a solid choice, with low distortion numbers, so currently that's the favorite. I'm wondering if anyone has any experience with low cost receivers and the Polks, and if the speakers have any "preferences" for certain receivers that I should be aware of.
thanks,
nms
First post here.
- Denon DRA-375RD
- Sherwood RX-4109
- Onkyo TX-8222
- Sherwood RX-5502
thanks,
nms
You might consider going with a vintage receiver or integrated in that price range. You'll get more bang for the buck.
I agree with jesse's (f1nut) recommendation.
If you're going this route, i recommend the Denon dra-835r or the Luxman r-115 vintage receivers. They usually pop up often on ebay for less than $300.00SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
+1 look for an integrated amp (amp and pre amp in one unit) that will power those 10b's much more effectively than a low cost receiver.
One like this one would do nicely... shop around though. and the reason people would recommend a vintage integrated amp is you get much more oomph for your dollar going used.
http://cgi.ebay.com/Vintage-PIONEER-SA-7800-Amplifier-BEAUTIFUL_W0QQitemZ320186492515QQihZ011QQcategoryZ3280QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
here is another one that is a little rough around the edges, but is powerful even at 80wpc. http://cgi.ebay.com/PIONEER-SA-9500-II-80W-chan-9500_W0QQitemZ250190118374QQihZ015QQcategoryZ3280QQssPageNameZWDVWQQrdZ1QQcmdZViewItemPolkFest 2012, who's going>?
Receiver: vintage harman/kardon hk430 or hk730; Yamaha CR-820, CR-1020, CR-2020
Integrated: vintage Yamaha CA-600, CA-800, or CA-1000; CA-610II, CA-810, CA-1010, CA-2010
I've used a CA-610II with my Monitor 7As for almost 30 years...
Personally this is what I would go for with Monitor 10's and your audio (and budget) requirements...Mains.............Polk LSi15 (Cherry)
Find a vintage Marantz 2275. You can't go wrong there. But if not vintage the HK stereo receivers do a great job."SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Russ busts my chops when I recycle my photos :-)
I'll have to snap some photos of the other Yamahae around here sometime. The trick is to get good light.
The 1970s Yamaha components went very well with Polks of the same era; Soundscape in Baltimore sold tons of them (and not, I'm sure, just to JHU students such as your humble narrator). -
Thanks for the replies.
I am cautious about buying used because it's hard to tell what you're getting. From pics and a description, you can't tell if the equipment has been abused, misused, etc.
However, a retro looking receiver would go very well with the boxy polks... -
Since you're cautious about buying used, look for gear offered in our Flea Market or over at AudioKarma. In fact, for vintage power gear, AK would be the ideal place to shop. -
Don't forget about NAD! They've made some great little integrateds over the years.
Check this brand new NAD integrated out.
I'll take 40 of NAD's watts over 140 from just about any receiver out there.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Yessir....get yerself a Marantz!:cool: Frank Zappa voice here: 'You'll love it!':D -
Yup, that is so. Nice, non-grainy sounding (as is also the case for the aforementioned hk and Yamahas)
This little rascal followed me home from the swap pile at the town dump a few weeks ago. Haven't done much with it but verify that it works, though.
Got myself a Sherwood 4109 at Radio Shack for $70.00 after rebate. It was a Black Friday sale item.
OK, so Gordon Miller was pushin' the hk 430 with Model 7s, but 10s would be good, too!
and older Denon can be had for some good money denon 3300s are priced pretty good these days:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
NAD would be my choice in your shoes.Steve Carlson
Von Schweikert VR-33 speakers
Bel Canto eVo2i integrated amp
Bel Canto PL-2 universal disc player
Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
VH Audio Flavor 4 power cables
Polk Monitor 10B speakers, retired but not forgotten -
We're using a fairly old Pioneer Elite Pre, a Parasound 205wpc into 8ohms, 10A's & an old Pioneer Elite Tuner (for when we want to listen to radio), and the 10A's simply sound incredible. We do almost all our music listening on the 2 channel setup, guess that's because it sounds gooooooooooood!!
Enjoy!!Home Theater
Chane A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
2 - Channel
Polk RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
Premier Rack|Blue Jeans,Audioquest,Monster Cables|
