laptop computer memory info needed
edited November 2007 in The Clubhouse
This is prob a pretty simple ? for lots of people more computer savy than me..
but If i want to upgrade the memory in a notebook computer and double it from 1gig to 2gigs of PC4200, 2 x 512 MB DDR2, 533 MHz can any DDR2 memory work in there as long as the pins match up? So could i got with a PC6400 DDR2 with 800MHz and get more speed out of it? of do I have to stick with exactly what came with the computer? Meaning is has to be the same PC4200, but more capacity?
PolkFest 2012, who's going>?
Post edited by danger boy on
Welcome!
    on a side note.. i have an old desktop computer that uses RDRAM, and I just checked the price of it for 512mb.
    Holy duck tape! why did this RAM never come down in price? Considering my computer is so old it came with at the time a 40gig HD :eek: which was condsidered huge back then :p;)
    512MB PC800 RDRAM 800MHz ECC each $250 :eek::confused: and i need two :eek::eek:
    I hear ya on the RDRAM. It is cheaper to buy a mobo, proc, and ram than it is 2 gigs of RDRAM.
    Ben
    danger boy wrote: »
    Yeah, that's a real pain. Mine has 36GB with those RDRAMs too. 45ns seems a little cheaper.
    http://crucial.com/systemscanner/index.aspx
    pretty good tool for telling you whats compatible..also they have pretty sweet prices right now
    danger boy wrote: »
    Depends on the motherboard of the laptop and what it takes. Unless one of the first DDR2 boards, it should take 800mhz but you never know. If you mix ram, they need to be the same speed. You can mix them in some boards and manufacturers and the ram will step down to the slower speed. If the board doesn’t like that, it'll end up with BSOD's
    Testing
    Testing
    Testing
Welcome!
Welcome!
