SDA2's with dimensional tweeter??
Joe08867
In the interest of science I disconnected the dimensional tweeter on my SDA=-2's I think they sound much better without. Of course Polk figured it out long ago in the follow-up series so I am not a genius, I just play one on TV.
I have since reconnected the dim tweeter because I don't know if it would cause harm to the Amplifier running it or not. The amp didn't go into fault or anything. I also didn't try to blow my windows out with the volume level.
Do you guys know if it would be bad to run them without the dimensional tweeter? And if it is bad what can I do to make it ok??
I do want to upgrade the crossover anyway(Probably during my winter hibernation) but I am not sure what the mod would be to remove the dimensional tweeter side of said crossover. Keeping the Ohms right and all that.
Also do you think it is bad that the tweeter isn't centered between the drivers or would the placement in the cabinet be so insignificant that I wouldn't notice? It's been a while since I have heard 2b's or even 1c's so I have no point of reference.
I mostly play Vinyl and Classic Rock on this setup if that helps.
Any thoughts would be great on this.
Thanks Guys and Gals,:cool:
Post edited by Joe08867 on
Since Joe08867 and I have the similar SDA2's I would also be interested in answers to the same questions.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica
