Polk Momo 6.5
Systems
Systems Posts: 14,873
edited November 2002 in Car Audio & Electronics
Can anyone tell me if the polk momo's 6.5 will fit inside a 1994 Mitsubishi 3000GT
Testing
Testing
Testing
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    edited October 2002
    kim has a book that will tell you...
    but i dunno
    crutchfield.com may be of service too
    enter in your car and so on...
    -Cody
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    also -- if u really like the speaker and want to be "extra sure" -- sometimes the books are wrong --- i've had it happen a few times -- my suggestion is pull the door open and measure from the LIP of the cutout to the back wall or to where you're first obstruction would be (usually your window when rolled down)... measure end to end and then knock off about 1/4 of an inch -- that's you're maximum depth. -- compare that to the momo 6.5 top mount depth.
    if the momo is too deep by only a little bit (like 1/2 inch or something) -- i assume the momo 5 1/4 is probably a little bit less deep, and with the use of an adaptor plate, that may also fit if the 6.5 is too big.
    good luck dude.
    The Artist formerly known as PoweredByDodge
  • sntnsupermen131
    if it doesnt fit ill trade you my 96 chevy truck for your 3000gt
    those speakers will fit in my truck
    worth a try...
    -Cody
