plz!!!! such a mess here.. help!!!
kodemma
kodemma Posts: 7
edited November 2007 in Speakers
hi everyone.... i just joined this club nd very excited...
here's the thing...
i have a pair of r50 floorstanding spekers for my mains.... jbl center speaker
and(here's the problem) 2pairs of bioplar speakers... in 7.1ch configuration, is it ok to use 2 pairs of bipoles as rears?? or would it be too much...
i'm trying to get the most diffused sound field as possible...
my room is 15' by 12'...
plz somebody help me here...
Post edited by kodemma on
  • BaggedLancer
    BaggedLancer Posts: 6,371
    Are you using the rears side by side or are you using the dipoles as middlles and rears? For middle speakers they are fine, but I'm not sure if it is all that common to use them as rears....maybe someone else can clarify since I do not run 7.1 myself.
  • dorokusai
    dorokusai Posts: 25,576
    Yes.
  • cheddar
    cheddar Posts: 2,390
    I believe diffuse sound fields was the whole point of bipole/dipole speaker designs.
    http://www.polkaudio.com/education/tech_article.php?id=27
    The only reason to prefer non-bipole/dipole speakers in the rear (all other things being equal) is if you want to localize sounds with more accuracy like with instruments in music IIRC.
    tonyb Posts: 33,072
    If your trying to get the most diffused sound field than your doing fine.The trick is in placement in relation to your sitting position and height.Of coarse your room has a thing or two to do with it also.So whats the big mess?Surely(don't call me shirley),there has to be more to this.
  • shack
    shack Posts: 11,154
    I wish Doro would quit rambling on so much....:rolleyes:
  • McLoki
    McLoki Posts: 5,231
    I assume you mean use 1 pair of dipole speakers as side surrounds and another pair of dipole speakers as rear surrounds in a 7.1 setup.... If so - yes, it should work very well.
    The first change I would recommend (way before changing your surround speakers) would be getting a center to match your front speakers. For now though - just hook it up and enjoy.
    Michael
  • kodemma
    kodemma Posts: 7
    i really appreciate ll your advises, each one of you!!!LoL thank You~~!!
    ok ... here's one more thing.... my 2pairs of bipoles are in two slightly different shapes.. one pair is trapezoid and the other one's square... which one for side and which one for rears??? can nyone tell me??? possibly w/ exponation????
  • kodemma
    kodemma Posts: 7
    and "tonyb"... i'm sorry for kinda exaggerating earlier, it was because it has to be done is 2 or 3 days and i just started to be hooked in this ht thing like a month or two ago, so basiclly.... i have no IDEAs!!!!
  • kodemma
    kodemma Posts: 7
    and also was because i 'm reading articles and hints by going over many websites i can't even remember, and they are saying different things. i set up speaker this way from reading those articles, and next day i read different articles they say it differently and more convictively... i've ben doing this over and over again for a week.... tired...
    tonyb Posts: 33,072
    kodemma wrote: »
    Yeah,I can understand that.Lots of info out there that doesn't jive.Polk Audio and this forum,have been in the HT buisness for a very long time and any info gathered here is golden.Without seeing a picture of your room,all the response you get will be generalized.If your sitting position is set,you can have one set of speaks about 5-6 ft high and to your side.Another set behind you at the same height.Do not secure to a wall untill you demo a movie and like what you hear.You may have to move them a tad this way or that way.Because we don't know what the room looks like,it's kinda hard to go on from here.Furniture in your room,windows,open on one side to another room,carpet or wood floors,all have an effect on the sound.Alot of trial and error is needed on your part to decide what you like.Let your ears be the judge,and you won't go wrong.
  • kodemma
    kodemma Posts: 7
    thanks tonyb... yeah guess you're right .. i'm just in hurry here and trying to rush things... by the way.... can anyone answer my previous question about which pair to side and which pair to the back???
  • danger boy
    danger boy Posts: 15,722
    use the trapizoid shaped ones for sides.. the box ones for rears. not to tough there.
    there really isn't a whole good reason for even going 7.1 most movies are only 5.1 at best. so most of your movie watching won't even utilize the two rear speakers. but since you got em. hook em up.
    enjoy
    PolkFest 2012, who's going>?
  • kodemma
    kodemma Posts: 7
    thanks danger boy
  • kodemma
    kodemma Posts: 7
    this is how it looks like from top... 16' (L) X 12(W) X 8(H)
    And i've put my speakers this way as you can see .... is there any adjustment i should make????
    p.s i've put 3 speakers in front at my ear's level and sides, rears at 5' which is 1.5' above my ear's level....
