Speaker wire lenght clarification -please
kc77
kc77 Posts: 3
Hi all,
I'm getting mixed information and need clarification...please. I'm getting ready to install satellite speakers and have ordered 12 AWG wires. Since the speakers will be at different distances form the receiver, I'm confused as to the lenght of the wiring. Must the lenght be equal on all channels? Regardless of proximity to receiver? If so, then all speakers on the system must be equal to the most distant use?
Front spks to recv ~ 6 ft
Rear spks to rev ~ 20 ft
Your help is appreciated.
Post edited by kc77 on
    F1nut Posts: 52,244
    edited November 2007
    No and no. Just use whatever lenght is required, you'll be fine.
  • olilugo
    olilugo Posts: 405
    I actually believe keeping lenghts the same. for example keep the wire lenght for left, right and center the same at say 6ft or 8ft. keep the surround the same at say 20ft.
    Last I think 12AWG will be just fine.
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
  • McLoki
    McLoki Posts: 5,231
    You put speaker distances into your reciever when setting up your surround sound. I am sure the delay put in there is greater by far than any delay put into the system by speaker wires of unequal length. (and can be customized if needed)
    i.e. - give yourself a few feet of wiggle room to move the final position of the speaker a bit for best sound - but make the length custom for each speaker.
    Michael
  • EFW
    EFW Posts: 28
    olilugo wrote: »
    +1 :D
    AVR...........Onkyo TX-SR703
    TV.............Mitsubishi WD-62627:D
    HD DVD.......Toshiba HD-XA2:cool:
    Power.........Monster HTS 1600
    Mains.........Monitor 70's
    Center........CS2
    Rears..........Monitor 40's
    Sub............PSW12
    Cables........Signal Cable
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I'm in the same speaker length camp, but will say this.
    In this example
    From AVR
    RF 7'
    LF 12'
    SR 25'
    SL 20'
    In this example I wouldn't use 25' to all speakers, but keep the lenght the same as in front or rear. So front I would use 12' cable the rear 25'. Well my 2 cents.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • steveinaz
    steveinaz Posts: 19,546
    Your speakers would need to be hundreds of miles apart to make any timing difference. Your fine.
  • janmike
    janmike Posts: 6,146
    In my HT I keep the fronts the same, the rears the same and whatever I need for the centre channel. Cables are easier to sell if the pair is the same length.
    Mine:
    Front - 2 X 8 feet
    Centre 1 X 6 feet
    Rears - 2 X 30 feet
    Michael ;)
    NORTH of 60°
  • disneyjoe7
    steveinaz wrote: »
    I don't know why for sure but different wire length caused a feedback issue with a turntable once with me. I was young 12 and a bit stupid it wasn't until a salesperson at a Rat Shack asked about speaker cable and indeed was the problem. So ever since this I felt speaker cables need to be the same length.
    That stuck with me so much so when I ran speaker cables around in the attic for HT and whole house audio every speaker pairs have the same length if more then I would coil up near the speaker jack. I feel that quad cable shouldn't be used for speakers due to the fact the length of speaker wire would be different if ran from one speaker to the next speaker.
    In short caused me an issue before and isn't much work to make sure speaker pairs have the same length. :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Sherardp
    Sherardp Posts: 8,038
    As said thats why you have delay settings in receiver, cut to desired length, install, dial in the speakers, sit back and enjoy. Long cables just mean more cable management, which then equals a pain in the a$$.
  • disneyjoe7
    Well I hear that and see why newer AVR could fix that issue. But for me who listens to audio in a pure direct mode any AVR settings are out the door at this point.
    My porch speakers are using an amp with pre delays aren't part of it's thinking ever. ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Gaara
    Gaara Posts: 2,415
    steveinaz wrote: »
    I concur to a lesser degree. Talking HT I don't see speaker wire lengths causing any differences unless you are talking 100ft+ differences, or big disparities % wise like one cable is 5ft and one is 30ft (6x longer). Our ears can't pickup on the delays caused by varying speaker lengths below these levels since they are so insignificant.
    I think that making a wire longer then need be would be more detrimental then varying lengths. Using a wire longer then needed you are bound to get more noise, especially if it is coiled up (coil of wire = antenna) as well as added resistance.
  • WilliamM2
    WilliamM2 Posts: 4,810
    Sherardp wrote: »
    The delay settings are for the distance of the speakers from the listening position. They have absolutely nothing to do with speaker wire length.
  • McLoki
    McLoki Posts: 5,231
    WilliamM2 wrote: »
    True, but that is because sound from your speakers travels at, well, the speed of sound. Not very quick compared to the near light speed that current travels in a wire. No need to set up a delay for that.
  • jakelm
    jakelm Posts: 4,081
    McLoki wrote: »
    Sound might differ, thus the channel level.
    But realisticly.... Unless your going 100' with 24awg wire, you wont have a problem.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • jakelm
    jakelm Posts: 4,081
    Check this out..... Look at the Ohm specs on 1000'
    http://www.powerstream.com/Wire_Size.htm
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
