Monitor 40s or 30s as rears
Really how will the monitor 40's on 2 foot stands sound as rears with moniter 60s as fronts in a small room(14x16x8) they will be paired with a sub so bass is definately not an issue but im wondering if the monitor 30s are just as good if not better
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605 - Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rearsMirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere -Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers
Post edited by K-daugh on
the monitor 30s would be sitting on my 19" end tables but i am worried about the difference in the power handling between the 40s and the 30s because i am planning on upgrading my AVR setup to an Emotiva pre-amp/amp setup in the future. Also i am "Attempting" to match the tweeter heights all the way around the room except for my center channel(**** entertainment center at the moment)The monitor 40s will alloww me to do this on 24" speaker stands the monitor 30's will not unless i mount them to the wall . Am I just getting to ridiculous or will this really affect my sound The main use is for HTBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605 - Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Custom Jumpers -
First off...you gotta get those surrounds up higher. Unless you watch movies lying on your back on the floor....they are too low. You should try to get them at least a foot higher than your head height. 3 Feet is ideal though. I used Monitor 30's for awhile as surrounds and was quite impressed with them. Decent speaker for the price. I then went to monitor 40's for surround and liked them better. I felt there was better presence and more dynamics. In comparison..the 30's were quite a bit thinner sounding and a little hollow compared to the 40's.Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W
