Lsi-15, how to improve bass response
trumpet1
trumpet1 Posts: 2
Aplologies in advance for this lame question, but I find the bass response in my Lsi-15s lacking depth or deep resonance, (what are the right words?). They are sufficiently loud and boomy when cranking up the bass knob, excellent for classical and light jazz, but no better than my vintage (1985) Polk Moniter 7s. for traditional pop/rock. Currently they are bi-wired to a modern Onkyo high output low-impedence receiver, and I have also tried them with an older Adcom amp/pre-amp--not much difference. The room is 15' X 20', hard wood floors, sofa and a few chairs. Speakers are limited to being two feet from walls and ten feet apart, set in a corner. Have I done something stupid? Would a subwoofer help or hinder? Would anyone want to casually recomend a sub-woofer set-up if that would be recommended? I am an aging 54 year old audiophile and modern technology has passed me by. Any advice would be appreciated.
Rob
Post edited by trumpet1 on
  • polkatese
    polkatese Posts: 6,767
    edited November 2007
    Rob, welcome to CP! Yes, LSi15 by itself is lacking the tight, deep bass that you want. I paired mine with a REL Storm III subwoofer, to supplement and complement the low-end what 15 is lacking of. If I were you, I would experiment with amplifications first. There are lots of information in this forum on what Polkies use for amp. Do your search on. I use a Krell Integrated on my 15 setup, along with the REL, and been happy with it for the past couple years.
    Good luck.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • Frank Z
    Frank Z Posts: 5,860
    Location,Location, Location!
    Get them out of the corners and forward toward your primary listening position. Report back after you play with placment and before you buy something you may not even need.
  • danger boy
    danger boy Posts: 15,722
    try setting your Onkyo to large speakers and see if the bass increases... it should.
    PolkFest 2012, who's going>?
    treitz3 Posts: 20,008
    First and foremost, welcome to Club Polk! ;)
    trumpet1 wrote: »
    They are sufficiently loud and boomy when cranking up the bass knob....Any advice would be appreciated.
    First off, try leaving the knobs alone. You are only boosting a particular frequency range all leading up to one particular frequency which leads to an overemphasis on particular frequencies and an omission of others. This may be what you are experiencing. Other than that, amplification.
    Refer to FrankZ's 1st statement for instant change.
  • george daniel
    george daniel Posts: 12,096
    Frank Z wrote: »
    ^^^^^what he said^^^^^^
    I had a very difficult time with my 15's as far a getting the bass "right".Like Frank Z said,out of the corners,,,and I had to "aim" them straight at me,and had them a few feet from the rear wall as well. Good luck,,you'll know when you get em' "dialed in".
  • fatchowmein
    fatchowmein Posts: 2,637
    Trumpet1,
    How long have you had your 15's? It took almost a month for the bass on my 15's to improve. I did not play them constantly, 24x7.
    Welcome to the forum!
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Lots of great advice so far - I'll add a couple thoughts.
    Swap the left and right speakers, try the woofs firing inward. Adding a sub will certainly help with low end response and impact in your room.
    The only real 'upgrade' one could do to the 15's is replace the woofers. The DB series car subs should be drop in replacements (on paper) for the internal volume, port, and what the crossover is expecting- and will offer a lot better bass performance than the PSW250-ish drivers it has now.
    Cheers,
    Russ
  • Lowell_M
    Lowell_M Posts: 1,660
    RuSsMaN wrote: »
    Cheers,
    Russ
    Interesting tweak Russ. Do you know of anybody who has done this?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • Lowell_M
    trumpet1 wrote: »
    Rob
    I'm guessing part of your weak link is the Onkyo. What ADCOM gear did you try? The setup in my sig for my 2-channel system has tremendous, but tight bass. I credit the ADCOM GFA-555 for a good portion of that response. I did hear a setup at Chicagoland Polkfest in which I thought the 15's were a bit boomy, but I feel that they are pretty solid with good "slam" in my living room.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • RuSsMaN
    a_mattison wrote: »
    No, it's just been discussed, not realized yet. Mark almost did it with his 15's, but ended up selling them to try something different. It's been kicked around with a couple engineers, not just a passing thought.
    Cheers,
    Russ
  • Lowell_M
    RuSsMaN wrote: »
    Cheers,
    Russ
    :rolleyes::rolleyes:HMMMmmmmmm....... Just when I thought I was at a point where I didn't need to change anything for a while...
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    RuSsMaN wrote: »
    We tried this once on a pair of JBL side-firing speakers that closely resemble the LSi15's and the results added a discovery of a skipping CDP, and an extra [annoying] rattle coming from a loose piece of wood within the entertainment stand and added boom. Keep in mind, this was firing against a pretty big entertainment stand approx. 1 1/2' away from the stand that had a 2' wide side panel. If the scenario is the same, or close too it is not recommended for what you want to accomplish.
  • RuSsMaN
    The 15's are no lease breakers, I'll think he will be ok. ;)
    Cheers,
    Russ
  • Early B.
    Early B. Posts: 7,900
    a_mattison wrote: »
    That's part of your problem -- running 4 ohm speakers off a receiver that is not designed to handle it. It's no surprise that your bass is a bit thin. Depending on the model, the Adcom you tried may not have been sufficient, either. You need a powerful separate amp to drive those 15's properly.
    "God grooves with tubes."
  • trumpet1
    trumpet1 Posts: 2
    I want to sincerely thank each of you who took the time to respond. I relocated the speakers out of the corner, now playing off the same wall in the center of the room with the speakers reversed so that the woofers face each other....don't ask me, but to at least to my ears in this room the bass response is incredibly better with this arrangement. I'll experiment with my Adcom set-up again-- GFA-535 amp, GFP-555 pre-amp, (but no remote with the tuner). Maybe I'll try a subwoofer some day, but for now, what an improvement. You guys are the champs!
    Rob
    Now is it just me, or was this an example of how a thread is supposed to go? No quibbling, lots of suggestions and solutions offered and the original problem presented improved, with more suggestions to try. The point stayed on track and was centered on what Mr. trumpet1 wants to accomplish.
    Fantastic! ;)
  • AndyGwis
    AndyGwis Posts: 3,655
    Yeah, that went smoothly. . . a little too smoothly if you ask me. Besides Russ telling him to drop in some car subs, everyone gave him logical, practical tweaks. Surprised the usual suspects (you know who you are) didn't tell him he had to drop the oink immediately and get a 200+ wpc amp, or to dump the 15s and go with Tylers, or something along those lines :)
    Well done, team. I love it when a plan comes together.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
