Will my center channel match up with these surrounds?
stangjason
I have a Polk CSR and I'm thinking about ordering two pair of RTi4 for my surrounds. Will these match up ok or will my Polk R300 (fronts) and Polk R150 (rears) match and sound better with them?
Thanks,
Jason
Thanks,
Jason
Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1
Post edited by stangjason on
I don't think matching for surrounds really matters unless you listen to multi channel music.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
I do listen to music in the 5 speaker stereo though I prefer my system for movies. Will it affect my system that much when it comes to music. I'm uncertain I made sense but I do want these speakers for fronts and also rear surrounds of my 5.1 system but I'm uncertain how they'll match up to my CSR center which I don't mind the sound of at all though I'm sure there are better.
Thanks,
JasonPioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1 -
No, those RTi4s will not match the rest that well, but they will be the best speakers in your setup... much better than the current fronts.stangjason wrote: »Will these match up ok...stangjason wrote: »I'm uncertain I made sense but I do want these speakers for fronts and also rear surrounds of my 5.1 system but I'm uncertain how they'll match up to my CSR center which I don't mind the sound of at all though I'm sure there are better.
If you are determined you want RTi4s, you can try them with and then w/o the CSR using the phantom center setting. You may actually like the new sound better. -
VSchneider wrote: »No, those RTi4s will not match the rest that well, but they will be the best speakers in your setup... much better than the current fronts.
I have a similar post about this but I have a few ideas on what to do. Would I be better off getting one pair of RTi4 with at least a CSi3 or if I can splurge for CSi5 would my r150 or r300 suffice as rears?Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1 -
That would work...upgrade the surrounds when you can afford to.stangjason wrote: »I have a similar post about this but I have a few ideas on what to do. Would I be better off getting one pair of RTi4 with at least a CSi3 or if I can splurge for CSi5 would my r150 or r300 suffice as rears?
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
