Parasound 2250 Power Amp
Sherardp
Sherardp Posts: 8,038
edited July 2011 in Electronics
I was wondering if anyone here is using this amp. I have some questions about installation before I decide to purchase it. I was reading the manual and understand that this amp can be bridged to output 600-700 watts with an 8 or 4 ohm load. My question is this once I set the amp up for bridge mode, can I install both RTi12s according to the manual or do I need two of these amps? I dont want to make this go up in smoke or damage the 12s during install, any help would prove useful before I order. Thanks.
Post edited by Sherardp on
  • dkg999
    dkg999 Posts: 5,647
    edited November 2007
    If you run it in bridged mode, then it becomes a single/mono channel amp ..... and you will need two of them if you want to run in the bridged mode. One running in bridged mode for the right channel, one running in bridged mode for the left channel. Unbridged it is a 2 ch stereo amplifier ...... and you would need only one of them to drive your right/left channels.
    DKG999
  • Sherardp
    Dkg99 those were my thoughts as well. But the manual states how to setup the amp in bridged mode to include one speaker, then says to repeat the same steps to install another speaker on the same amp. Its kind of confusing, unless Im reading into this wrong.I was thinking you could set the amp up as a mono amp, have the amp output 600-700 watts per a pair of speakers, make sense. Kind of hard to explain this. Check out the manual and see page 8. Thanks for your help.
    http://parasound.com/pdfs/OWNER_GUIDE_2250.pdf
  • dkg999
    dkg999 Posts: 5,647
    I think what it's trying to say is that you could run two speakers off of the bridged amp, in mono mode. So if you had 4 RTi12's, and for some reason wanted to run two of them for the right channel, you could connect both right channel speakers to the one 2250 in bridged mode, and then connect your two left channel speakers to another 2250 running in bridged mode. There's no way you can run stereo speakers off of a bridged amp.
    DKG999
  • Sherardp
    Ahhh ok got ya, thanks allot for showing me the light. I was lost in space with that one. Any thoughts on this amp running my Rti12s? What are your thoughts on Parasound gear?
  • dkg999
    dkg999 Posts: 5,647
    I have the Parasound HCA-1500's powering my Magnepan 1.6QR's. They sound incredible. Parasound is good stuff!
    DKG999
  • Ethancf
    Ethancf Posts: 473
    My 2205 has been running my HT for years...still makes everyone's jaw drop when she's singing and she never breaks anything close to a sweat!
    THE SYSTEM
    Polk Audio LSiM 707 Mains
    Polk LSiM 702 f/x Surrounds
    Polk Audio LSiM 706 C Center
    SVS SB-17 Ultra Subwoofer
    Rotel RSP-1582 Pre/Pro
    Rotel RMB 1585 Amplifier
    Oppo UDP-205 Blu-ray Player
    Samsung PN64D550 64" Plasma
  • Sherardp
    My last question is should I run one Parasound 2125 bridged per RTi12 or should I just buy the 2250 and power the fronts with that and put the Outlaws on the center and side surrounds?
  • Early B.
    Early B. Posts: 7,900
    Sherardp wrote: »
    Be careful. Some amps sound worse when they are bridged.
    You could purchase a pair of monoblocks or a killer 2-channel amp for the same amount of money you'd spend on two Parasound amps. If you want to stick with Parasound, consider buying a used Parasound 1500A.
    "God grooves with tubes."
  • Sherardp
    What would you recommend, I was thinking of going just the 2250, but Im open for anything really. Also with the 2250 how do I install this thing? Is it one speaker per A or B channel or both speakers on side A or B. Audioadvisor is listing this amp for 1199, is that a good price?
  • G-2
    G-2 Posts: 533
    Can't comment on that price but we can tell you that a Parasound 1500A powers our polk 10a's with plenty of room, we're really quite impressed with this amp! You're looking at the 2200? What are you driving with them, based on what you just described we'd recommend that you power the front 2 channels with 1 2200. It should be good depending what kind of speakers you're driving. What kind of speakers are you driving? ohm? power rating? Just curious.
    Chane
    A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
    Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
    Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
    2 - Channel
    Polk
    RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
    Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
    Premier Rack|Blue Jeans,Audioquest,Monster Cables|
  • Sherardp
    polk Rti12s are what Im using. I wanted to use the Parasound to power the fronts alone, then use the outlaws for the rears. Im also thinking of trying something new from D-sonic, which would be the Magnum 1000S. Any thoughts on amps using ICE power technology?
  • dkg999
    dkg999 Posts: 5,647
    In my experience, many amps don't sound as good when run in bridged mode, and sometimes run a lot hotter (ie temperature wise!). I would use one 2250, using the speaker A terminals to connect your right/left RTi12's. The speaker B terminals are for if you wanted to connect a second set of speakers that you wanted to listen to in place of your main RTi12's. It is not usually recommended to have both speaker A and B on at the same time (even if the manual doesn't say that). Hope this helps! The Parasound amps are great for sound and build quality. I am not sure on the AA price, but the HCA-1500 that the 2250 replaced sold for about that same price unless you caught a sale on them.
    DKG999
  • wingnut4772
    wingnut4772 Posts: 7,519
    I have the 1500A also and it's pretty nice. A bit on the warm side with bass galore.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Sherardp
    Thanks guys, very helpful info, that A and B setup was throwing me off a little. I now have to decide, either Parasound 2250 or D-Sonic Magnum 1000S. Im just doing some homework on both. Will post up once I decide, any thoughts on ICE power?
  • deseroner
    deseroner Posts: 155
    edited July 2011
    ok , i was wondering this also, i read the manual to set 2-3 ohm when bridging a 4ohm load, also i did bridge my lsi15 on each side, they sound awesome so far, anyone has done this also.
    receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
    mains-lsi15 4ohm 250w modified&db840 nordost blueheaven spk/rca
    center : snell xa1900 4ohm 250w,nordost flatline
    subs-klipsch-ksw10/athena asp-4100
    rear-OWM3 - 8ohm 100w
    surrounds-klipsch rs-7 150w
    amp-5ch.-aragon 3005 thx ultra 2 nordost blue heaven ls pc
    power.c-bpt cpc/ps.soloist ci.
  • deseroner
    edited July 2011
    has anyone bridged there lsi15's with a parasound 2250
  • niente
    niente Posts: 68
    edited July 2011
    Boatload of super clean headroom .. love my Para
    Onkyo TX-SR804 receiver
    Parasound 5250
    LSI 15's
    LSI C
    LSI FX's
    PSW1000 Sub
    OPPO 93
    Sony CDP-C315 CD
    Monster AC line cond
    Audioquest, Blue Jeans & Monster wires/connects
    40" Sony Bravia XBR6
  • deseroner
    edited July 2011
    fastz28 wrote: »
    the parasound 2250 has plenty of power for your speakers no need to bridge:biggrin:
    they seem to shine when in bridged mode :)
  • deseroner
    edited July 2011
    i actually , got told it can only be bridge with one speaker for separation, you can bridge two , but it will be the same, so if i want to bridge it with lsi15 i would need two amps. so 385watts x2 4ohm stereo is enough for lsi15 i suppose.
  • PrazVT
    PrazVT Posts: 1,607
    edited July 2011
    Hey Sherardp - I have both the NC2250 and the Halo A21. The 2250 ran my A7s before I got the A21, and I'd say you'll really like the 2250. The A21 is higher current and little warmer, but the 2250's no slouch. The A & B thing is just if you want to power 2 different sets of speakers (you figured that out by now). But I'd guess that two 2250s (in bridged mode) would maximize the 500w power handling on those 12s!
    On a side note - I run an HCA1000A bi-amping my CSi A6. The one time I turned on bridge mode, there was an audible hum so I switched it back to stereo. Is that normal?
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited July 2011
    PrazVT wrote: »
    I get that also in bridged mode on my hca1000a, it's a slight buzz/hum. Can't really hear it when watching a movie at loud volumes, but it's also anoying when nothing is playing... don't know if that's normal or not. :confused:
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • PrazVT
    PrazVT Posts: 1,607
    edited July 2011
    Yes - exactly the same thing. You're right, it's more annoying when nothing is playing. But the amp works great if I bi-amp using both channels, so not a big deal I guess.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
