FX500i to FXi3 consider downgrading?
Dannieboiz
My system consist of RTi6 and CSi5 in the front and FX500i in the rear.
I've been lurking around for decent FXi5 but they're so hard to come by second hand. I found a decent deal on FXi3 that I'm seriously considering. Just curious on the sound of it compared to the FXi5.
I do alot of 5 channel stereo music listening so matching sound is important movies wise, the FX500i do just fine since it's always lower anyways.
Would it be a good move if I jumped on the FXi3 and sell the FX500i?
Sammy UN55C6400
Onkyo TX-SR875
Def Tech: Mythos One, Three, Six
Velodyne DPS-12
MartinLogan Dynamo 10
Onkyo TX-SR875
Velodyne DPS-12
Post edited by Dannieboiz on
as i havent experienced either of the fx500i or the fxi5 i wouldnt be able to tell you if it would be a good idea or not. however, i own the fxi3 and if its something you decide you would want, i wanted to buy the fx500i's but could never find them used so i would love to trade you.
