Tube dac with Bad fuse
thejck
thejck Posts: 849
edited November 2007 in Electronics
So i finally picked up a Lite audio dac-68 from audiogon and got in last week. Got it all hooked up and spent a long evening listening to it wednesday night. Turned it all off and unplugged it and didnt turn it back on till Saturday morning.
The dac turns on. shows me that that it was picking up a digital signal but there was no audio coming out of it into the preamp. Tried all sorts of things to figure out whats wrong. made sure the preamp was working. tried a differnt digital source tried both unbalanced and balanced interconnects and nothing.
pulled it open and there was a fuse that was bad. run down to radion shack and get a replacement matching 2 amp fuse and it works again. So I am really excited now..This is the second bad experience I have had with a dac. Previously bought a Entech 205 number cruncher from ebay and it arrived Dead wouldnt turn on. So I am thrilled that this is working again now.
Anyway..anyone have any ideas on why a fuse would go bad like that. I went out and bought a new surge protector as well. Could I have something else wrong. I dont usually have problems like this. Never have had to replace a fuse before in any other equipment...and never had anything die on me from surges before.
Any advice on what could be wrong.
    heiney9 Posts: 25,669
    Don't sweat it. Probably a hundred reason's. If it becomes frequent then I'd be concerned.
  • thejck
    thejck Posts: 849
    its been so long since I have had my speakers sitting there and finally got it all hooked up along. so you could understand the frame of mind I was in this mornig when I found it was not working..anyway i am glad its working and its satisfying
