DIY short stands - $14 project cost
BaggedLancer
Total cost was $14....keep that in mind. These are just temp stands until I actually find a company that make something that looks decent.
Plywood, carpet, pvc pipe, spray paint, anti-skid drawer mat, 16 screws and some Super 77 spray glue.
Despite looking like they came out the rearend of a goat, they serve their purpose for now and will hold me over.
Post edited by BaggedLancer on
They look like crap, dude. Throw 'em out. Burn 'em. Give 'em away. To someone with cats. For scratching posts. Drive over 'em. Just get them outta your house!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Oh, and you're welcome.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
damn, i didnt even see that, they do look like cat scratch posts
I think the design is actually ok. I wouldn't have spray painted carpet though. (they do look kind of crappy). If you just use some MDF, rout a nice edge on all the pieces, wrap the PVC in some aluminum flashing, spend a little time painting, and you have some nice stands for about 20 bucks. (also rout a channel for the speaker wire so it goes through the stand from the bottom).Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64 -
Yea, I am really not much of a DIY person when it comes to building things I design, I just needed a quick solution till I can find a company that makes something like this which I am pretty sure doesn't exist.
I don't own a router and the only saws I'm actually good with is a sawzall and gasoline cut off saw.....any type of finish work is NOT for me.
My new amp is coming this weekend so that means im setting up my 2ch on my bureau and i just didn't want to put the speakers on the bureau....I assure you these are only temporary.
If you did the same thing, but use real wood, stain it, and paint the PVC black, they would look fine.
