Subwoofer popping sound
Early B.
Early B. Posts: 7,900
I know this issue is very common, but I don't know which terms to use for the forum's search feature, so I gotta ask it again --
My sub has a loud "pop" sound upon power on and power down, although to a lesser extent. It occurs whether the pre is on or off. I've tried cheater plugs on the sub, but that doesn't work. The sub is plugged into a different wall outlet, but they're probably on the same circuit, if that matters at all.
Two questions --
1. Does the popping sound damage the amp or the driver?
2. How do I get rid of it?
Thanks.
"God grooves with tubes."
Post edited by Early B. on
    VR3 Posts: 29,394
    edited November 2007
    Wont damage it ---
  • jakelm
    jakelm Posts: 4,081
    Serioulsy, I would just leave it on...
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • Early B.
    jakelm wrote: »
    I would, but it hums a little. Not a problem when a movie or TV is playing, but in quiet moments it's noticeable.
  • McLoki
    McLoki Posts: 5,231
    Wont damage anything. I get the same thing from my sub and front speakers as the caps discharge. The volume level is pretty low (well under 88db) so I would guess based on that - less than one watt is going to the speakers.
    I have tried all kinds of sequences to stop the popping but nothing works. Now I just live with it and don't worry about it.
    Michael
    tonyb Posts: 33,067
    Have you tried another sub cable?Or power cable? Try plugging it into a power conditioner,sometimes that helps.My first guess is the sub cable though.These little annoying things can drive you nuts.
