Stereo Subs?
AudioFilet
AudioFilet Posts: 235
edited November 2007 in 2 Channel Audio
First real post here.
I thought I might ask you guys for some opinions on something I want to try.
I have a set of LSi9 speakers, and I am thinking about pairing them up with a set of identical Sony subwoofers. This would be done by using my Outlaw Audio ICBM connected to the pre-outs of of my Outlaw RR 2150. The output of the ICBM can be configured for stereo, so the left & right sub outputs would be correct for each channel. It can also be configured for mono.
Anybody have any experience with a setup like this, or have any thoughts?
2 Channel rig:
LSi9"s (modified xover's) & HSU Sub
Harman Kardon HK 990 Amp
Onkyo C-S5VL SACD
Music Hall MMF 5.1
Furman Elite 15
HT rig:
HK AVR-745 & Polk Monitor Series
Post edited by AudioFilet on
    VR3 Posts: 29,418
    Stereo subs ROCK!
    Anytime you can correctly position a bass guitar with force in another room (outside the listening area due to soundstaging) you are cooking with grease!
    Its the only way to get totally unlocalized bass, with the clarity, tone, texture, and deepness possible with music...
    Only a few have heard it and I highly* recomend it...
  • Face
    Face Posts: 14,340
    The only thing better than stereo subs are speakers that play low enough that you don't need subs.
    VR3 Posts: 29,418
    Even then
    You gotta have subs...
    Subwoofers are where its at...
    Only speakers I have EVER heard that 100% do NOT need a subwoofer....
    And I can list them on one hand ---
    Wilson Audio X1
    JM Lab Grande Utopia
    And maybe, just maybe the 1.2TL -- for the majority of music...
    Granted, I want to know if I need it - I can reproduce 20-20 with no issues...
    YMMV
  • Face
    Face Posts: 14,340
    Even then
    Wilson Audio X1
    YMMV
    For home theater I agree, but not for 2 ch. stereo. I've never heard any of those speakers, but I'm sure my 15" Tannoys aren't far behind them.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    I didn't always feel this way, but I sure do now. Stereo subs can REALLY enhance just about any listening experience. In a lot of listening rooms (spare bedrooms, dens, home offices), the room is far from optimal. Sometimes the setup of the two main speakers in the best imaging position, doesn't always equate to the best bass position, and vice versa.
    This is where stereo subs can REALLY shine, even if crossed over VERY low. You can place your speakers for the best image and soundstage, and place yours subs for the fastest, most articulate bass response. Hey - if you get lucky and get the optimum placement on your speakers alone - kudos, and more power to you - but in my experience, it's not the 'norm'.
    You're on the right track Filet de' Audio, only problem that jumps out is the Sony part of the subwoofer equation. There is a greater chance than zero they lean toward the boomy, one-noteish side of bass - and probably aren't fast enough to match the bass and midbass speed of the LSi9's.
    Cheers,
    Russ
    VR3 Posts: 29,418
    I looked in the Showcase, looks like the Tannoys use 15" woofers --
    Which to me might as well be considered a type of bass driver...
    But I'm assuming it does mids as well...
    I pretty much can't stand large main speakers (wide) -- and I hate side firing big woofers, and I dislike even more multiple small front firing woofers... its counter productive to me...
    I like very narrow baffle, and small midbass drivers ---
    If I were to go 2 ch, no subs --
    It'd definitely be with a system with around 8 midbass drivers - 4 per tower... solid to about 30hz...
    Fast transiets, dynamics, and still have the bass authority to blow your mind... all while remaining clear...
    And I would still have a subwoofer in the mix, probally crossed around 30hz or so to fill in those very last octaves...
  • Face
    Face Posts: 14,340
    Correct, the crossover is at 1.1k I believe.
    At least we can agree on something. :D
  • jm1
    jm1 Posts: 618
    The main objective is to realize full range sound. There are various methods of implementing this objective. You can use single cabinet full range speakers or separate cabinet speakers dedicated to certain frequency range. A separate cabinet systems requires more setup and configuration, but that does not imply it will not be as good or better. The end result is what really counts.
    Well said.
    I would add that the hardest part of using subs for music is finding one to use in your system. Most subs on the market I wouldn't use for HT. Fewer could be used for music.
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
  • AudioFilet
    So, any suggestions as to a good sub for music??
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
  • Early B.
    Early B. Posts: 7,900
    AudioFilet wrote: »
    Hsu.
    What's your budget?
    "God grooves with tubes."
    VR3 Posts: 29,418
    Two of those ---
    Two Crown XTi4000 and you will be good to roll! ;)
    I kid...
    Yep, whats your budget?
  • AudioFilet
    Maybe $2000?
    I was kind of looking at some of the tube subs from SVS?
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
  • RuSsMaN
    Actually, Polk has almost a dozen new subwoofers that can fit just about any application, at a lot of different pricepoints. Just to throw one out, a pair of DSW500's would be great for your application.
    Cheers,
    Russ
  • Early B.
    For two G's, I'd get two of these:
    http://www.epiksubwoofers.com/CaliberOverview.html
    VR3 Posts: 29,418
    Is it strictly music?
    If so - you can do alot better for the money for music...
    VMPS is definitely one --- the Dedicated subs, or their Original Subs -- and a nice solid amp with a Paradigm X30
    And as Russ pointed out, Polk has come out with an array of awesome subs
    I definitely wouldnt recomend SVS for music first -- not by a long shot..
    I'd say...
    REL, Martin Logan, VMPS, ACI, HSU, Then SVS for music...
    Lots of options out there for 2k
  • AudioFilet
    This would be strictly a 2 channel music system. I love the RR 2150, but will probably upgrade that eventually.
    The Caliber subs look like good ones.
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
    VR3 Posts: 29,418
    I've never heard Epik --
    But I can't imagine them being that great for music, but for HT I sure can ---
    If you plan on spending 2k -- you have sooo many options, you want something low compliance and fast -- not a SPL machine...
  • Early B.
    It's really the quality of the amp that matters most. So I'll amend my suggestion by saying that I'd switch out the BASH amp on the Epik subs or order a passive one.
    I like 15" subs for music. Lots of square inch, little movement, so it's hardly working. Plus, 15 inchers should provide a huge soundstage and a nice foundation for the music to rest upon.
  • AudioFilet
    A lot of choices, yes. I have heard a lot of good things about the HSU subs.
    The new Polks look good too, but I already have one of the Sony's. It's a newer moder, SA-W3800 (have not hooked it up yet). If I like the sound of that one, I can get another one and see how that works. If I don't like it, I can hook those up to the HT system and get something else.
    I'm open to suggestions though.
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
  • AudioFilet
    Why would the SVS subs not be good for music??
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
  • Early B.
    AudioFilet wrote: »
    Amps are so-so, IMO, which makes them a bit boomy (that's great for HT). For music, you want bass with finesse.
  • shack
    shack Posts: 11,154
    Almost anything but the Sonys. I tried the little Sony "giant killer" from a few years back (SA-WM40). It was horrible, even with the recommended tweeks. Fortunately I was able to unload it to someone else who believed the hype that it was a huge bargain.
    I think the SVS would be fine. I've heard them in a couple of realy nice 2 channel rigs and they were excellent. One was with LSis and the other with some Maggies. I tend to like a sealed (acoustic suspension) sub in a 2 channel rig. I think they are tighter. REL comes to mind but they are a little over your price range.
  • jm1
    jm1 Posts: 618
    AudioFilet wrote: »
    I have two of the original SVS PC-Ultras in my system; they are excellent for music. I can not comment on any of the other SVS subs as I have not heard any of them.
    Arthur Schopenhauer
  • cstpeter
    cstpeter Posts: 387
    Martin Logan subs are very well regarded for music. There are two used Martin Logan Depth subs on Audiogon that would run $1700 for the pair (more than half off MSRP).
    http://cls.audiogon.com/cgi-bin/cls.pl?homesubw&1198786980
    http://cls.audiogon.com/cgi-bin/cls.pl?homesubw&1200372994
    Von Schweikert VR4-jr
    Valve Audio Predator
    Denon DVD-2900
    PS Audio Digital Link III w/Cullen Level IV Mods
    Pro-Ject Xpression w/Blue Point No. 2
    Graham Slee Special Edition 2
    PS Audio UPC-200
