amplifier or receiver????
K-daugh
K-daugh Posts: 467
which is better and does an amplifier offer the same things as a receiver how do they differ and which is the better way to go with polk monior seriesi appreciate the help guys some of this stuff can be overwhelming but im learning through the forums
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605:mrgreen::mrgreen: - Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere:mrgreen: -Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers
Post edited by K-daugh on
  • engtaz
    engtaz Posts: 7,669
    edited November 2007
    Simple things are, AVR's usually are rated at 8 ohm. Speakers come in various rages 8,4 and 2 ohms. The current draw from the speakers can clip the signal going to the speakers and damaged the speakers and/or AVR. Amps are made to deliver the amp loads and current to drive speakers better.
    engtaz
    engtaz
  • Pauly
    Pauly Posts: 4,519
    seperates are always better if you have the coin to drop on some decent gear.
    P
    Life without music would
  • cfrizz
    cfrizz Posts: 13,415
    Welcome KDaugh.
    Get a receiver that has all the bells & whistles you want that has PREAMP OUTPUTS for all channels. I always recommend 200wpc 5-7 channel amps. Just to get it done in one shot.
    However, if you do have the money, get all separates to begin with & you'll be all set.
    Good companies for separates are Outlaw Audio, Parasound, Rotel B&K Sunfire, Nad, & Adcom. You will get more bang for your buck buying used from Audiogon.
    Kex, OUTSTANDING breakdown post!!!
  • Pauly
    Pauly Posts: 4,519
    cfrizz wrote: »
    Welcome KDaugh.
    He might only want 2 chnl
    P
  • K-daugh
    K-daugh Posts: 467
    ok so I only want to amplify my front speakers so i would probably go with a 2 channel amp but i also have a sony 500 watt receiver i want to run the surrounds through this...no???????i also have my tv/dvd/cd hooked up to this ...but my question is how do incorparate the two if i use the receiver as a pre amp do i still get the tv/dvd/cd and where would a run the amp from?? what terminal do i runn off of and what type of cable do i use p.s. my receiver is 5.1 channel 500 watt old style sony (its about 8 years old)
    Custom Jumpers
  • Pauly
    Pauly Posts: 4,519
    Does it have pre's on the back?
  • K-daugh
    K-daugh Posts: 467
    my receiver does not have pre outs that sucks is there any other way ??? thanks for all the help by the way guys
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    I know im going to upgrade so when i do do i buy a receiver and an amp or a pre amp and an amp so i take it the pre amp will run my tv/dvd/cd sound and the amp will juice up my fronts (if i go with the 2 chnnel)
    Custom Jumpers
  • Pauly
    Pauly Posts: 4,519
    2 chnl is the shiznit
    P
  • K-daugh
    K-daugh Posts: 467
    i take it the cheaper but better way would be to buy a quality receiver then add a 2 channel amp to it
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    Im just realizing that my mirage bps150i subwoofer has a built in 5 channel amp does anyone have feedback on this
    Custom Jumpers
  • Pauly
    Pauly Posts: 4,519
    K-daugh wrote: »
    Seperates are the better yes, depending on your budget. You can get older good gear thats affordable and just upgrade from there. If you stick around here you almost have too constantly upgrade. Highly addictive :)
    P
  • K-daugh
    K-daugh Posts: 467
    right now i have a polk cs1 center with monitor 60s as fronts and older style bose 201 bookshelfs for rears ....i want to swap those out for monitor30s or 40s ....i also am pumpen the system with a mirage bps150i sub which is very stellar...my receiver needs to be upgraded the most im thinking another sony looking to spend under 800 what do you guys think
    Custom Jumpers
  • Dave38
    Dave38 Posts: 101
    K-daugh wrote: »
    which is better
    A stand alone amplifier.
  • xandra
    xandra Posts: 291
    I'm in a similar fix as K-daugh, and given the excellent info here, am considering an amplifier (cuz I THINK my Front speakers - RTi10s are underpowered) but... my Receiver does have pre-outs
    My current SETUP:
    Onkyo 705 Reciever:
    • 100 watts minimum continuous power per channel, 8 ohm loads, 2 channels driven from 20 Hz to 20 kHz with a maximum total harmonic distortion of 0.08 %
    • 115watts minimum continuous power per channel, 8 ohm loads, 2 channels driven at 1kHz, with a maximum total harmonic distortion of 0.7%Others: 600 W
    • 125watts minimum continuous power per channel, 6 ohm loads, 2channels driven at 1kHz with a maximum total harmonic distortion of 0.1%
    Quote from Manual: "If you want to use a more powerful power amplifier and use the AV receiver as a preamp, connect it to the PRE-OUT jacks, and connect ALL speakers and the subwoofer to the power amplifier. If you have a powered subwoofer, connect it to this AV receiver/AV amplifier’s PRE OUT SUBWOOFER jack."
    CURRENT SPEAKERS (All Polks)
    Fronts: RTi10's: Recc'd Amplification: 20-300 watts/channel
    Surr's: RTi 6's & 4's Recc'd Amplification is 20-125 watts/channel
    Center: CSi3 Recc'd Amplication 2-180 watts
    Reason for considering purchasing an Amplifer:
    when playing classical music, pianissamo (sp?) passages are all but lost, bass sounds muddled and boomy. I'm currently ASSUMING the problem is that my recently purchased RTi10's are underpowered. I could be wrong as the tonal quality (tho not detail) improves when I use one of the 7 channel modes.
    I like the features (including 3 HDMI v1.3a inputs) and ease of use of the Onkyo Reciever. I'd probably pay up to $2500 for a receiver with these benefits but adequate power, but my sense is that no such item exists...
    QUESTIONS:
    What's the difference between 'Reference Amplifier', 'Integrated', and 'Power' amplifers?
    Can I assume Onkyo is really outputing 100 watts when in stereo mode - or is it really closer to 50watts per speaker?
    Apx: How many 'True' watts am I getting per speaker when in 7 channel mode? -- would this be (100w/7?)
    If i bi-Amped the fronts would I be doubling the power sent to the fronts? (Onkyo requires that you use the surround back connects to do so - thus reducing to 5 channel output) Crutchfield told me that I can't bi-amp this Reciever?!
    Can I amp only 2 channels (given the Onkyo quote above)
    • If so Given my specs:: would a true 125 watt amp be a marked improvement, or am I better off with 2@200(+)
    would I be better off going with 200w x 2 channel amp or a 5-7 channel @ 125watts?
    If 200watt x channel: Can anybody point me to true 200 watt 2 channel Amp under $1000 (preferably well under)
    Options I've run into (and spec confusion) --- comments please:
    2 channel x 200(+) I'd like to keep this Under $1000, but this is what I turned up...
    Parasound: Model 2250: 2 channel x 250watts RMS x 2@8ohm $1200
    http://www.legacyaudiovideo.com/paclmo22new.html (also avail at audio advisor)
    Emotive RPA-1: 2 channel x 200watts watts RMS per chan in a dual mono configuration $699
    "Reference Power Amp"
    http://www.emotiva.com/rpa1.html
    seemingly conflicting specs: also says " • 200 watts RMS per channel into eight ohms"
    is this 200watts per speaker in stereo mode??? or by dual mono
    OTHER OPTIONS:
    NAD C272 Stereo Power Amplifier
    2-channels 2 x150W Mini. Continuous Power into 4/8 ohms --$799
    799.99
    HUH ON THESE SPECS:
    •2 x150W Mini. Continuous Power into 4/8 ohms
    • 220W, 340W, 460W IHF Dynamic Power into 8, 4 and 2 ohms, respectively
    MULTICHANNEL by 125watts:
    EMOTIVE: LPA-1 6/7 chan. 5x125w + 2x50* $499
    EMOTIVE: LPA-1 6/7 Channel Audio Power Amplifier
    http://www.emotiva.com/lpa1.html *
    Sounds like the best deal at 125watts, reccomended elsewhere on this site, BUT??? If my issue IS power then will this be a SUBSTANTIAL improvement. IS THIS 125 watts per channel or 50???
    5x125 watts + 2x50 = 7 or
    6x125 watts, configurable
    • Rated Power Output: Channels 1-5 (All Channels Driven at 0.04%THD, 120vAC/ 60HZ supply) 8 ohm: 125 watts / 4 ohm: 225 watts
    • Channels 6-7 (All Channels Driven at 0.05%THD, 120vAC/ 60HZ supply) 8 ohm: 50 watts / 4 ohm: 95 watts
    Adcom - GFA-7605 5 Chan HT Amp : 5 channel 125 watts RMS x 2@8ohm $799(demo)
    Adcom - GFA-7605 5 Channel Home Theater Amplifier
    $799 Audio Avisor
    http://www.audioadvisor.com/prodinfo.asp?number=ADGFA7605
    Power rating: 125 Watts continuous x 5 (8 ohms 20 Hz-20 kHz, all channels driven);
    Outlaw Audio Model 7125 7-channels 125 watts RMS x 2@8ohm -- $999
    http://www.outlawaudio.com/products/7125.html
    •Power Output: 7 x 125 watts RMS at 8 ohms, all channels driven from 20 Hz to 20kHz with less than 0.05% THD
    sorry so long, but soooo confused and intimidated.- Alexandra
    LR Setup:
    Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
    Onkyo 705 & Denon 3808ci Receiver, Onk 875
    Parasound 2250 Amp
    Sony 26" KDL series Bravia LCD
    Panny DMR-EH75 Recorder
    Panny DVD-F87 (5 disk DVD player)
    NAD T585 (DVD/SACD)
    Yamaha DVD-C961 (5 disk SACD/DVD)
    SciAnt Explorer 8500HD Cable Box
    Orig & 5Gen iPods, , Wii
    Plans/Fantasies:
    • 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
  • carpenter
    carpenter Posts: 362
    What's the difference between 'Reference Amplifier', 'Integrated', and 'Power' amplifiers?
    an Integrated amp combines the preamp and amp in one box. you can connect your source directly to it (CDP, SACD ..) a Power amp, needs a preamp unit. most integrated amps in your budget can be used as power amps (skipping the pre circuit). what you're after is a Power amp (the Onkyo is the pre).
    Can I assume Onkyo is really outputting 100 watts when in stereo mode - or is it really closer to 50watts per speaker?
    Well .. yes and no. The Onkyo has one simple low current power supply for all channels.
    a stereo amp in your budget will have a nice high current toroidal transformer. Higher current = better driven drivers = better sounding 10s
    If i bi-Amped the fronts would I be doubling the power sent to the fronts? Onkyo requires that you use the surround back connects to do so - thus reducing to 5 channel output) Crutchfield told me that I can't bi-amp this Reciever?!
    No. Forget biaping this way, or biwiring. none will deliver more power to your 10s
    As I said the Onkyo has one power supply for all channels. I see no electrical benefits in your suggested connectivity.
    Definitely. 2 channel music will sound much better. 5 channels are used only in HT (and fancy surround modes). The rears require less power, and used just for effects. your center will enjoy more power, but again, you've mentioned Music as you main goal, and the center will get more power from the Onkyo if you use a separate power for the mains.
    I see no need for you to go this route with your current setup and budget, better go for a better stereo amp. If 200watt x channel: Can anybody point me to true 200 watt 2 channel Amp under $1000 (preferably well under)
    All the brands you've mentioned would yield better sound for music in comparison to your Onkyo, and are considered good value.
    Other brands you might want to consider:
    odyssey audio (karthago , stratos)
    Adcom (GFA 5400)
    Rotel (1080 RB)
    Cambridge audio (640D 740D 840D)
    Xindak
    and many more
    Good luck
    Lea
    "If the global crisis continues, by the end of the year Only two Banks will be operational, the Blood Bank and the Sperm Bank. Then these 2 banks will merge and it will be called 'The Bloody **** Bank'"
  • engtaz
    engtaz Posts: 7,669
    Adcom 555 or 555II 200 wpc for around 350.00 or less. Very Nice class A/B amp. Great price per watts amp. Carver also.
    engtaz
  • BAD ASP
    BAD ASP Posts: 361
    I jumped on this website because years ago with absolutely no knowledge I decided to spend some coin on a really good pair of speakers. I went to a local audio video store and auditioned all of the big names at the time. Infinity,Martin Logan, Klipsch, JBL, Kef etc, etc. Funny thing I kept going back to the big old coffins from Polk. I went against the accepted wisdom and let my hearing do the talking. I took the big boys home and the wife had a meltdown. She did agree that they sounded unbelievable but !@#!$%$!. I won my first and last argument and I have been thankful ever since. Well on to your question and how this all relates. I don't possess the knowledge that a lot of the other audiophiles on this website do. I have always trusted what I heard because it was all I really had. I started with Sherwood then on to Onkyo and last was the Denon 5700 at 170 wpc X 5.1. I was really happy with that setup but I kept coming back to this site and decided to go separates. I kept the Denon and used it as a pre for a couple of months until buying the matching pre for my amp. Once I amped up some of my favorite music I immediately noticed the broader sound stage and the depth of the music. When we went to the HT I was struck by the clarity of the background sounds that we all enjoy; the background restaurant chatter and clatter, the rustling of the landscaping behind the characters, sirens off screen coming onto the screen. Everything we appreciate in Home theater was more pronounced and clearer at lower listening levels. Once again I am not a techno wizard I am merely stating what my hearing has told me. If asked I would say unequivocally that separates are better. But I must also add that the quality of the separates may dictate the level of the sound improvement. My experience with separates is limited to what I have. I do not possess the broader range of equipment knowledge, I leave that to others on this site. If a Denon 5700 is better than some low end separates, others on this site will know and speak up I am sure. All I can say is first trust your hearing before you open your wallet. Once you are zeroed in on what it is you like pull the trigger, life is short.
    Amp: sunfire cinema grand signature 5ch 425 wpc
    Side surround amp: Sunfire 2 X 300
    Processor: sunfire theater grand V
    Fronts:: polk sda-srs 1.2
    Rears: Polk LSiFX
    Side surrounds: Fxi5
    Center: (2)polk LSiC's
    Sub: svs pb-13 rosenut
    Hd-Dvd: toshiba xa-2
    Blue Ray: oppo bdp83se
    Projector: sony vw60
    Screen: Da-Lite 106"
    APC S20 Power conditioner
  • engtaz
    engtaz Posts: 7,669
    BAD ASP, nice write up.
    engtaz
    engtaz
