Polk c500.1 running 2 x DB12 DVC's?
najahaja
Heya,
I want to run my 2 x DB12"s (DVC's) in a sealed box. Will the c500.1 do that, or will the subs be underpowered?
I am not going for SPL, just daily listening, but I also want to crank it up occasionally.
I see the specs on the 12's are 360w each, and the sib 500w, but I think it will still run them fine myself.
Thanks in advance
edit : I see I cannot hook up the 2 x DVC's to make it 2 ohm stable (being 4 ohm speakers).
Would I be better off going for the C300.1, which can run either 220W x 2 at 2 OHM, or 450W x 1 at 4 Ohm (either one is possible with the 2 x DVC's)
Thanks in advance
Post edited by najahaja on
yea you can. dual 4 ohm?
Heya,
Thanks in advance
Youre right, you cant run a pair of dvc subs off the 500.1 as its not 1 ohm stable. You could wire each sub in series and then bridge them for a 4 ohm load but then youd be getting half the power.
Its really hard to find a 300.2 these days unless you get one used but that would be a better configuration than a 500.1 at 4 ohms.
Can you exchange your subs for SVC models? Then a 500.1 would be perfect for it.polkaudio sound quality competitor since 2005
sorry your right. i did some reading and you need dual 2 ohm or svc like he said
