Internet Connection Problem
audiobliss
audiobliss Posts: 12,518
edited November 2007 in The Clubhouse
Ok, so I'm having some difficulties with our connection.
The wireless computer has been giving errors off and on, but repairing it has always got it back up and running. However, tonight I'm having problems with MY desktop connecting, and it's WIRED to the router. I've never had any difficulties with it before.
However, for the last day or so several of my programs (AIM, MSN Messenger, xfire) would just randomly be disconnected and reconnect, and tonight I lost my connection completely. Repairing the network didn't work because it couldn't refresh the IP address. So I rebooted, viewed my network connections, it said I was connected, couldn't get anything online working, though. So I repaired it with the same success as before. So then I reset the cable modem and the router and rebooted again, and now I'm online.
Why would I be having difficulties with my wire desktop? Is this signs that our old Linksys router is going out? Should I just go ahead and buy a new one? I'm not very fond of it anyways, so I want to do that, but if that's not the problem I want to know what IS the problem.
Thanks!!
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
  • audiobliss
    I just lost connection and had to reset the Linksys router again!
    What's this mean? If the router's on it's last leg, I'll just bring a WRT54G home from Walmart tomorrow.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • greg2350
    greg2350 Posts: 544
    Yep same symtoms as when my linksys went out.
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
  • Serendipity
    Serendipity Posts: 6,975
    Try to wait a while for the Linksys to cool down first. I had the same experience with a few old Linksys routers - they overheat and fail. But it doesn't mean it's dead. Usually moving the unit to a well-ventilated, cooler location makes a world of difference.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • fatchowmein
    fatchowmein Posts: 2,637
    My linksys is on 24/7/365 and will occassionally need to be powered off and on every month or two. However, I have discovered that my provider, Comcast, will drop the connection about twice a year for a few hours.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I thought hubs died on the wireless side mainly not the wired side.
    But I say that just to say I'm surprised but not shocked that the wire side died. Anything can die, just me I replaced a ton of stuff everyday. ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • audiobliss
    Hmm. I'm not sure what to do. I've been online fine now for about an hour or so. But I'd still really like to upgrade to something a bit less archaic! :eek:
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Refefer
    Refefer Posts: 1,280
    Deathbed! heh, My first linksys loved to do that. Also, it should be mentioned, if you're engaging in any torrent downloading, the older linksys' have a fun habit of crashing routinely. I needed to get a firmware patch for my current one so that it wouldn't crap out when I downloaded stuff.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • audiobliss
    No torrents here. Just your typical browser and messengers.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • fatchowmein
    If you disconnect the router and plug the desktop directly into the modem, does the problem go away. Of course, it can be a pain just to reconfigure the desktop for a direct connection depending on what your setup is.
    If the problem goes away, it's probably your router. Replace it.
    If the problem doesn't go away, the issue is with your PC (or O/S) or with the modem.
    Oh, yeah. Always check the connection. A bent Cat5 cable or a bad clip may give you intermittent problems.
    Good luck!
  • audiobliss
    Thanks for the tip.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • SKsolutions
    SKsolutions Posts: 1,820
    Same issue, same hub. When under load and generating heat, it would switch to using one IP/MAC addy for both/all computers. You can upgrade the firmware if you have the patience for such a thing, but you can also as easily 'brick' it during the attempt. If you want to give it a try, you might want to upgrade it with the open source firmware that will give you much more control over it. You can turn up/down the wattage on the radio etc.
    http://lifehacker.com/software/router/hack-attack-turn-your-60-router-into-a-600-router-178132.php
    I've yet to try it on the older Linksys, but I plan to over the winter.
    -Ignorance is strength -
  • jakelm
    jakelm Posts: 4,081
    And I was about to go get my wrt54g Linksys router today. Now problems with it already?
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • SKsolutions
    It's better than any alternative that I've found. If you figure that they are on 24/7, and are capable of sending and receiving hundreds of terabytes in their life cycle, it's cheap. My average lifespan on them has been around 3 years, so at 60$, it's not even a set of wicked awesome Monster IC's.
  • edbert
    edbert Posts: 1,041
    My Linksys wrt54g has been sitting behind a dresser on its end for 5 years running 24/7 and I have yet to have an issue. I have had to reset the router, modem, etc. periodically, but I don't consider that to be anything major when I might have to do it twice a year and it takes all of five minutes. Shoot, I didn't even update the firmware on it until a month or so ago.
    And there's about enough room between the wall and the dresser to fit the router. Just buy what you think will work best for you jakelm and what you feel most comfortable with. We have all had problems with all brands.
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
  • audiobliss
    I updated it with the newest firmware listed for it on Linksys' website about a week ago.
    jakelm wrote: »
    No, no, we're using a much older router, NOT the WRT54G. If this turns out to be the router failing, the WRT54G is what I'm going to buy to replace it.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
