YSP-4000 and DSW Pro 400 Questions
Krispinn
So I set this system up in my livinging room last night.
I don't think the Polk remote is having any effect on the base volume, the light blinks and blinks back its volume message but I don't hear an elevation in base output. I can increase the output on the YSP and notice increase base output to the Polk.
I hooked the Sub to the Sub out on the YSP and the LFE on the Polk is this proper? Am I getting double filtering?
Should I hook this Sub out to either the L or R channel on the Polk?
If I bump my sub out cable I get a thumping feedback, I will try a new cable this evening and see if that fixes the problem. It seems as if there is a loose connection in either the cable to the LFE input or internally to the LFE input. I will experiment with this tonight and hope to resolve this problem. Anyone with experience with this or hear of similiar instances please respond.
Any help will be appreciated.
Post edited by Krispinn on
We have the exact same setup YSP-4000 with DSWPRO400, and are having the same problem(s) (non-responsive gain control on the Polk). Did you ever figure out what the issue was? Was the sub bad or was it the YSP's sub out connection. Or was it a cable? Your response would be greatly appreciated.
-Rick
