SRT Subwoofer
mudphud
mudphud Posts: 2
Just bought a brand new (at least, never used) subwoofer from an SRT system based on all the reviews for the SRT system, but I can't find much info on the sub itself. Anyone have the specs for it and what would be the equivalent sub in Polk's current sub lineup?
Paid less than $500 for the sub from craiglist, which seemed like a good price, but I wasn't really sure. What do you guys think?
    edited November 2007
    I think you have been ripped off.The sub from the SRT speakers was designed .....well,for those speakers.It had a control box with all the adjustments needed to blend it in.Did you get the control box?As a stand alone subwoofer,if that is how you intend to use it,your going to be dissapointed.Sorry for the negativety my man,but,should check here first.
  • ESavinon
    ESavinon Posts: 3,067
    SRT Subwoofer Specifications:
    High Velocity Compression Drive band-pass enclosure
    Weight: 87 lbs, 39.47 kg.
    Size: 31 1/2" H x 12" W (at top of cabinet), 14.1/8" W (at base) x 23 1/4" D. Metric: 117cm H x 30.46cm W (at top of cabinet), 35.89cm W (at base) x 59.02cm D
    One SW1080 10" woofer each cabinet
    One SW1081 10" woofer each cabinet
    High flow, low turbulence Power Port
    Built-In Amplifier Power: 300 Watts RMS
    Dual voltage operation - 115V or 230V, switchable
    "Auto On / Off" circuit
    Frequency Response: -6dB at 16Hz (in 3,500 cubic foot room) to -3dB at 90Hz
    Maximum Output: approx. 120dB SPL above 30Hz (pair of woofers in 3,500 cubic foot room at 1 meter)
    Variable height feet with removable spikes
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • AdamRagland
    AdamRagland Posts: 521
    welcome to the forum though........
    VR3 Posts: 29,756
    Dude
    the SRT sub is a MONSTER
    You will love it
    Might need a crossover for it though
  • mudphud
    mudphud Posts: 2
    Thanks for the specs. I played with it a little bit today, just plugging it into my existing receiver/amp and it rocked the couch. I did notice that it was only kicking in at the very low frequencies. I guess I'll have to play with it some more before I know if I need a seperate crossover.
  • Early B.
    Early B. Posts: 7,900
    mudphud wrote: »
    If you're using the receiver's crossover for HT and music, you don't need a separate crossover.
    "God grooves with tubes."
    VR3 Posts: 29,756
    The SRT subwoofer the most explosive subwoofer I've ever heard....
    It was almost uncomfortable to be in the same room with it...
    If Polk could do that subwoofer design in an actual subwoofer design - I'd buy it for HT in a heart beat...
    PHENOMINAL attack
  • dorokusai
    dorokusai Posts: 25,661
    They can, they just haven't.....yet. The new DSW series is miles above their older subwoofers and the next couple rounds of more advanced subwoofers are pretty tight as well. The MicroPro is making its rounds on a local demo and is a blast to play with.
    I don't see anything that will unseat my SVS Ultra/2....but I'm not embarrassed to have a Polk subwoofer in my house anymore. In addition, the in-wall subwoofers are very effective and I'm sure the GA Polkfest attendees can attest to that fact.
    VR3 Posts: 29,756
    The Sub Inwalls were PHENOMINAL
    definitely wouldnt be embarressed to have those - they missed the very very last octaves, but they had the SLAM...
    I'll be keeping my eye on some Polk subs for HT...
