Need a cheap 2-channel receiver
Mazeroth
Mazeroth Posts: 1,585
edited November 2007 in Wanted (WTB) Classifieds
Looking for a solid state 2-channel receiver to do impedance measurements with when I design loudspeakers. If it doesn't have bass/treble controls then all the better!
Thanks!
Post edited by Mazeroth on
  • dorokusai
    dorokusai Posts: 25,577
    Does it need to have a tuner?
    mhardy6647 Posts: 33,957
    Just out of curiosity... why do you need a receiver/amplifer to do (speaker) impedance measurements? I drive loudspeakers right off my signal generator when I DIY T/S parameter measurements.
    That said, I am sure I have a spare -- or two -- gathering a layer of sediment in the basement. PM me if you wish and I can see what's on the slab.
  • Mazeroth
    Doro, the simpler the better. No tuner required.
    What do you mean by off your signal generator? I'm using SoundEasy which requires the use of two "probes" with various resistor values that need voltage to measure properly. Everyone I know of uses a solid state amplifier/receiver to take their impedance measurements. The only other way I'm aware of is if you have a device like the Woofer Tester 3 which is USB powered and doesn't require a separate amplifier:
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=390-804
    And yes, if you have some collecting dust by all means let me know what you have.
    Thanks guys.
    I use a tried and true Heathkit (analog) signal generator.
    http://sound.westhost.com/tsp.htm
    You do need a resistor to calibrate to read impedance directly (and accurately), but you don't need an amplifier if the signal generator can output 1V into the low impedance load.
