Acoustic Research Cables?
jayman_1975
Does anyone know if Acoustic Research component video cables are worth a hoot. I am looking to put a good set with my Arcam DV27. I have been thinking about Blue Jean cables but found a good deal on this 3 foot set of AR.
Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W
Arcam CD37
Vandersteen V2W
Full Metal Jacket, cool player. If you are only going 3 feet, I doubt you'd be able to notice any difference between the two. I'm using the same Belden wire as the Blue jeans, bought on the cheap and had them terminated with BNC's. Player is Cambridge 540D V2.-Ignorance is strength -
I would use BCJ, I've been disappointed by AR cables before."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks for the reply. I just noticed after posting this that the AR cables are from Radioshack and retail at $60. Blue Jeans retail at $50 for 2ft. What would be a little higher end then these without gettin really crazy priced. How would Audioquest component cables compare? I have seen them used for $140.Onkyo TX NR 5008 modified by The Upgrade Company
Arcam CD37
Vandersteen V2W -
I have a 3 foot set of AR component to let go of if interested.
I find AR to be a decient value, they are better quality than basic store cables, but cheaper than rip-offs like Monster.
