sub hookup
noobaslt
noobaslt Posts: 26
hi all
i want to connect my sub too amp but its only does all freq.
i have thought about connect from my dvd sw chanel to amp left chenel
because sub are svc
would it work?
Pioneer DEH-P880PRS
db6501
more coming soon.... :rolleyes:
Post edited by noobaslt on
  • McLoki
    McLoki Posts: 5,231
    edited November 2007
    I really have no idea what you just asked (other than would it work). Any chance you could try to rephrase the question?
    Include these specifications...
    Are you trying for home theater or 2 channel?
    What brand and model of subwoofer?
    What brand and model of amplifier?
    What brand and model of pre-amp or Reciever?
    What do you want it to do that it is not doing?
  • McLoki
    McLoki Posts: 5,231
    Ok - a cup of coffee later I will give it a shot.
    I think your question is this - (correct me if I am wrong) - You have a DIY (passive) subwoofer you want to power with an external amp and want to know where you hook that amp up to your reciever....
    Starting at the reciever (assuming it is an AV reciever with a sub out option) hook an RCA cable from the sub out on the reciver to the input on your amplifier. Hook the speaker output on your amplifier to the inputs on your sub.
    The reciever (when the sub is hooked up to the Sub or LFE out RCA jack) will take care of the crossover so don't worry about sending a full range signal to the sub.
    Well - was I close??
    Michael
  • noobaslt
    noobaslt Posts: 26
    yea thats what i asked you so it wont get full range singnal..... ok thx
    (soory about that coffee helped)
    Pioneer DEH-P880PRS
    db6501
