hsu vs velodyne
I'm currently using a velo vrp 1000, I'm thinking of selling and getting a new sub how much better of an upgrade would the hsu stf-1 be? Is there any other subs under $400.00 that are recommendable.
thanks
thanks
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
The STF-2 is under $400, I have one, and its amazing.
The extension down to 25Hz (STF-2) instead of 35Hz (STF-1) will certainly be worth having if you watch movies. If your only requirement is music, there isnt much content down that low, so the STF-1 would be a cheaper alternative without losing anything you need. -
stf-2 here. Mostly movie, and when I'm listening to some types of music, I flip it on. Other than really needing a corner placement, it's easy to place, and blend fairly easy. It's good for movies, and great for music. Least expensive upgrade that made a 'wow' kind of difference.-Ignorance is strength -
Yeah, definitely go with the STF-2.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I'll triple or quadupple(SP??) the stf-2Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin T2 w/Roon (NUC) DAC: Denafrips Pontus II Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Pass X150.8 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Morrow M4 ICs & Audio Art SC-5 ePlus, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
