Outdoor plasma
jvarnadoe
jvarnadoe Posts: 52
edited November 2007 in Electronics
Back in March I bought a Panasonic th42px60u plasma and mounted it outside on my patio with a Sanus articulating wall mount. It runs off of the DirecTV HD box in our bedroom via a 45 ft. Blue Jeans Cable HDMI cable. The RF remote function works like a charm for this set up. The patio is pretty large 29x12, so there really isn't any danger of it getting rained on, but I'd like to fabricate some kind of covering to protect it. Has anyone else already been down this road? I thought about utilizing this fabric - [HTML]http://www.sailrite.com/Categories/Glen-Raven-Sunbrella-Supreme[/HTML] It has an acrylic flocking on one side that should hopefully prevent scratches on the screen.
Also, should I be concerned about cold weather? I live in Florida and we don't get freezing temps very often, but I don't want to ruin the TV by leaving it outside during a freeze. Maybe I'll just remove the TV from the wall and store it inside on cold days since it only takes about 5 minutes to detach it from the wall plate.
Any suggestions are appreciated.
Polk collection:
SDA SRS 2.3 w/RDO-194's
SDA 2 w/Vampire BPHEX
M5jr+
CS245i
RT15i
RT25i
RT35i
LC65i x2
Post edited by jvarnadoe on
  • shawn474
    shawn474 Posts: 3,052
    Maybe it's just me, but there is no shot that I would leave that thing outside overnight much less for seasons at a time!!!! Freezing temps or not, i would imagine that moisture still collects and that can't be good for the tv.
    Shawn
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • jvarnadoe
    jvarnadoe Posts: 52
    Eight months and no problems so far. It's a convenience thing. The kids like to watch movies, Nick and the Disney Channel while in the pool and it's nice to be able to slip outside to the patio and watch football or the Speed Channel. It takes away from the spontaneity if I have to lug the thing outside.
    I'll be the Club Polk outdoor electronics longevity tester. I also have a pair of RT35i's that are serving patio duty.
    Polk collection:
    M5jr+
    CS245i
    RT15i
    RT25i
    RT35i
    LC65i x2
  • Sherardp
    Sherardp Posts: 8,038
    some sort of Vinyl covering may work attached using small bungie cords. Or you can have some sort of plexiglass casing made for it.
  • zx_toth
    zx_toth Posts: 417
    jvarnadoe wrote: »
    Some of you guys have way too much money :D Good for you! :)
    Zsolt
  • WilliamM2
    WilliamM2 Posts: 4,808
    I wouldn't use any type of vinyl, it will collect moisture inside, and it will be trapped. Use a breathable fabric. Something like a canvas car cover, that can breath.
  • I-SIG
    I-SIG Posts: 2,243
    I would also be concerned about dust and dirt collecting inside the unit. Obviously it's not as big a problem in FL, but here in AZ it would be a serious concern.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • SKsolutions
    SKsolutions Posts: 1,820
    I don't know the specs on that unit in particular, but their pro line has a huge temp and humidity latitude. I hope it carries over to the consumer line! I agree with the advice of WilliamM2. Moisture will be drawn to a "dry" area. If you use anything that retards the vapor/moisture, you will draw moisture in, then trap it around the unit with no ventilation. Bad. A breathable fabric is best, unless you want to hermetically seal it in it's own enclosure. Like a big sneeze guard. .
    -Ignorance is strength -
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Well with Plasma's coming down in price, I'm considering mounting one outside also. But I don't feel anything will prolong the life of the unit one way or the other. Thinking you're taking a hit being outside with moisture issues you may lose 20 to 30% of it's life, which is fine if I could get 5 - 7 years out of it.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • jvarnadoe
    jvarnadoe Posts: 52
    Thanks for the feedback. I'll have to look for breathable fabrics to utilize for this project.
    Polk collection:
    M5jr+
    CS245i
    RT15i
    RT25i
    RT35i
    LC65i x2
