WTB Vifa tweeter (1)
treitz3
The title says all. Thank you.
Post edited by treitz3 on
OK, I would just like to clarify. I am searching for 1 Vifa tweeter for an LSi speaker. I realize that there are different Vifa's out there, so I just wanted to clarify. TXS!~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
vifa la tweeter !Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
el bumparoonie....~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
What on earth are you doing with a Vifa LSi tweeter?
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=264-555
Just dosnt say Polk- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
It's an experiment, I'm always tinkering with something or other. I have read before, or had a conversation with Mark Suskind....one of the two and was informed that the Polk Vifa tweeter was made to Polk's specifications. If this is the case, I don't want to have a timbre issue for my experiment and am in search of a Polk LSI based tweeter.Vr3MxStyler2k3 wrote: »What on earth are you doing with a Vifa LSi tweeter?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
el bumparoonie II.........~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
The Partsexpress one also requires you to cut the top and bottom to make em fit right? XT25TG30-04
I have the XT25TG36 but don't know if its compadible. It looks exactly like the stock polk tweeters.Receiver - Onkyo HT-R340
Front - Pioneer S-HF21
Center -Onkyo SKC-340C
Surround Back - Polk R15 <--Ticket to club polk
Subwoofer - Onkyo SKW-340 -
how do you can burn ded a vifa tweeter??? you run a disco room at your home???
my lsi9 make my music happy with tha vifa tweeters. -
^ I like this guy ^:)HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
Phasearray wrote: »The Partsexpress one also requires you to cut the top and bottom to make em fit right? XT25TG30-04
the faceplates are removeable and swappable... -
Their is a guy selling a pair on ebay in my area for $59
Oh, my apologies. I never updated this thread.
I have already acquired said tweeters. Thank you though.
Hey, I'm looking for a Vifa tweeter for my LSiC. Where did you buy it and are you thinking of selling it?
Mine is blown I think. And I'm looking for a replacement. Any suggestions? Thanks! Onkyo 805, RtiA5s, Csi5, Rti6s -
Is it puffed up or sunk in?
Have you pulled it to check for a loose wire?
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
