to pre or not to pre
phipiper10
phipiper10 Posts: 961
edited October 2007 in Electronics
Looking for some advice/feedback please -
My plan is to obtain an Anthem pre-2l like was just sold in the FM. This pre because - it is tube based, has HT pass, a remote and supposedly is flexible with different tubes that can be used and all this around my $500-$600 price point.
The other thing I've been considering is changing out my Rotel for Parasound A23 which probably could be done for not a lot more $$.
My questions are these-
Any other options for the type of pre I'm looking at?
Do you see any synergy problems with the Rotel or Parasound amps being used with the Anthem pre?
Will I really lose anything going from the 330w to 225w
Which should I change first the amp or the pre?
I'm getting the impression the Parasound might be warmer than the Rotel - coupled with the tube CD player and the pre - I'm wondering if this might be too much?
Thanks guys.
Rich
Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2007
    I have heard the Anthem with a parasound, well, ok, Doro's BBQ is not exactly any parasound, but, I would say you would be very happy with your proposed combination, excellent quality nice pre great sound and the parasound amps really can put the bass out, I would go for it. Another option would be the Anthem hybird amps, tube input and ss output, there were two of them at the SC Polkfest in 06, they got hooked up and stayed hooked up, when they come up they are reasonable in cost, if I remember they were 150 @ 8 ohms at pushed the SDA's with power to spare.
    RT1
  • Early B.
    Early B. Posts: 7,900
    edited October 2007
    Change the pre first.
    Consider other amps besides Parasound. Take your time. Do lots of research. You want to make sure your amp change is vertical, not lateral.
    "God grooves with tubes."
  • phipiper10
    edited October 2007
    Yeah good point on doing the pre first..I suspect I could more easily "try" different amps before committing to anything.
