5-channel amp Opionions
Lowell_M
Lowell_M Posts: 1,660
edited October 2007 in Electronics
My ADCOM GFA-555 is moving to 2-channel duty in my living room and now my HT will be totally powered by my H/K AVR-635 unless I add another amp.
I love the ADCOM sound. Any 5 channel amps you all might recommend I try out that woudl be under...say... $800? If I don't come up with anything, I'm getting another GFA-555 or a 545
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
  • del44
    del44 Posts: 686
    edited October 2007
    Maybe a Rotel RMB-1075. You can pick one of these used for around $700. Good performers with very few issues. I've been using one in my system for awhile and haven't had one problem.
  • McLoki
    McLoki Posts: 5,231
    edited October 2007
    This is a dirt cheap option that should work out really well with your H/K. If I had the funds, I would get it for a second HT rig...
    Michael
    Edit - not to mention it would make a great test for the difference between an amp and an AVR. (since the power is about the same between them) If you don't like it, I would think you could resell it for what you paid, if not a profit.
    Edit #2 if you want to stick with Cathys 200wpc mantra - here is a nice 3 channel rotel well within your budget. (with local pickup for you - BONUS.....)
  • ben62670
    ben62670 Posts: 15,969
    edited October 2007
    Ben
  • brijenjas
    brijenjas Posts: 311
    edited October 2007
    I have one of these (LPA1) and am extremely pleased with it and it's partner, LMC1.
    http://www.emotiva.com/lpa1.html
    Replaced an AVR340 and GFA 6000 with the LPA1 and their LMC1.
    They are also releasing a 5 x 200w/ch RMS, somtime early next year.
    Will sell for $699.
    http://emotivalounge.proboards54.com/index.cgi?action=display&board=amps&thread=1192051012&page=1
    http://forums.audioholics.com/forums/showpost.php?p=318242&postcount=47
  • brijenjas
    edited October 2007
    ben62670 wrote: »
    That's a great price for that Adcom.
  • Lowell_M
    edited October 2007
    brijenjas wrote: »
    I agree. I was thinking about branching out a bit and trying something different. Have been curious about Rotel. That GFA-7500 is tempting though.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • jakelm
    jakelm Posts: 4,081
    edited October 2007
    Thats a great price for that Carver, that amp is no slouch.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • Lowell_M
    edited October 2007
    Ok.. Aside from what's available here or on audiogon is there anything I owe it to myself to try, or is my price range limiting me quite a bit?
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2007
    Rotel, Sunfire, Parasound, Outlaw, are all good options as well. And yes your price range is limiting you for a 5 channel amp.
  • ben62670
    edited October 2007
    a_mattison wrote: »
    Umm... mine is only $600. You can find Parasound for $800 if you shop hard enough. Going from 150 Watts to 200 is nothing in output. You would gain 1 dbl, and there is a huge difference in price. I have an A/D/S car amp that is 30 watts a channel, and it kicks the crap out of a lot of these 100 watts channel amps out their. Read the specs on any amp you are looking at. I particularly look at dampening factor, headroom, and THD in th .007 range. Do research before you buy.
    Happy hunting
    Ben
    Ben
