New Home theatre set up
Hi
I am planing to prepare one home theatre system using in ceiling speakers for our new home. i was searching the web for good speakers . i am really confused. i finally came up with the following and i would like to hear your opinion since i am not a professional and this is my first home theatre
front:Polk LC 80 i
centre: Polk LCi-C
Surround: Polk LC 80fx
Planning to buy Dennon receiver AVR 2037CI and may be Axiom SUB EP 350
front:Polk LC 80 i
centre: Polk LCi-C
Post edited by rinren on
In my opinion Tower speakers are better but it also depends on how much room you have.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Those are the inwall versions of the LSi series. It should sound great. I would at least make sure your AVR has pre-outs though and don't be shocked when everyone suggests getting an amp. Do a quick search of lsi and avr or reciver for lsi and you will see what I mean.
Thanks for ur replay . I heared tower speakers sound best , but my house is prewired for surround syatem . That is why I opted for LSi.
Welcome Rinren.
That is fine. What we are also telling you is that the LSI series is 4ohm which the Denon will have a hard time pushing. You will also need to invest in separate amplification in order for the speakers to sound the best & to not risk damage to them from the receiver being overdriven.
Again please do a search here on the board for LSI & receivers.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Rinrin I started on this forum with a similar question. I finally broke down and got a killer amp, dual subs and a 1080p projector. I spent a bit of money, but my home theater is the talk of the neighborhood and I would do it exactly the same again.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
Hi thanks a lot
i heared about Bang Olufsen speakers .
anybody has any experience with this brand ????
