A/V Receiver question...
shawn474
I got to rearranging the audio components today. I noticed the monitor output on the back of my sony str-da5es receiver. What is this for? Is it for an on screen display? Does it offer any advantage to hooking up the receiver throught the outher outputs? Any advice would be appreciated. Thanks in advance.
Shawn
Shawn
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Front: Polk LsiM703
Rear: LSI fx
Here is the user manual it may help.Michael
NORTH of 60° -
janmike,
I have the manual. It doesn't really go into any detail on this hookup except how to do it. My question is are there any advantages to hooking it up this way either visually or sonically? Or any other advantages at all? Just wondering if it is better to hook it up through the monitor output than the other outputs.
ShawnShawn
Front: Polk LsiM703
Rear: LSI fx
DVD Player: Sony PS4 -
I am not 100% what that is for but since it is an output you may be able to direct the programming screens to the TV or other monitor device. On my Proceed Pre I can do that and then take it to the input on the monitor.Michael
NORTH of 60° -
Yep. That's how mine works, too. I use S-video.
Not sure how it works for newer receivers with HDMI. It may not be necessary.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
It looks multi channel capable for audio and video. My Marantz has that feature, and I use the second channel A/V for a second room with a shared wall.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
