Need Help Again
cfrizz
For the first time in my system I have 12volt triggers. One in my Rotel CD player & the other in my Sunfire prepro.
Is it possible to use these to be able to turn my cd player on & off via the prepro? I'm already tired of turning it on & off manually. I had it plugged into my Denon which took care of it.
When I went into Radio Shack asking about it.."He looked at me uncomprehendingly like cows at a passing train.":D He didn't think it could be done, or the other person he asked either.:rolleyes:
So tell me fellas, is this possible? If so, please post a link to what I need to get since I've never seen one.
Thanks much!:)
Thanks much!:)
It can be done if the cd player has a 12v "in" trigger. I'll get the link.
Here:
http://www.radioshack.com/product/index.jsp?productId=2102950&cp=2032058&f=Taxonomy%2FRSK%2F2032058&categoryId=2032058&kwCatId=2032058&kw=headphone+cables&parentPage=search_________________________________________________
If it does not, there are some power centers that have 12volt triggers on banks of outlets. That could do it for you as well.
The Rotel does have a 12v trigger in.
The Sunfire has 12vdv outputs. They reference it using it with the Sunfire amp. But I take it you can use it for a cd player instead.
Thanks for the link.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
