Carefull matching...amp & preamp...
pearsall001
pearsall001 Posts: 5,400
edited October 2007 in Electronics
Having a CJ PV14LS2 tube preamp, I'm finding out that it's not a simple task of just adding an amp. I was looking at the PASS Labs x150 & x250 but something about their impedence (Correct me if I'm wrong) doesn't match up well with the CJ, or so I've been told. It was recommended that the Audio Research 300.2 would be a great synergy match. Also the Classe' CA201 was also mentioned.
How does one match up the amp & preamp? This is a new audio lesson I'm going thru so I can use all the info you can throw at me.
Any thoughts on CJ amps? I'm sure they would fit like a glove with their own preamp.
    heiney9 Posts: 25,724
    edited October 2007
    If you have anyquestions about Pass stuff old or new check out the Pass Labs forum over at
    www.diyaudio.com
    More than likely Nelson will answer any questions you have.
  • dorokusai
    dorokusai Posts: 25,661
    edited October 2007
    The only "problem" I've had with gear is output gain. I've had a ton of gear and never experienced a impedence problem or audible mismatch. YMMV.
  • phoneisbusy
    phoneisbusy Posts: 867
    edited October 2007
    heiney9 wrote: »
    www.diyaudio.com
    Or try the commercial site.
    http://www.passlabs.com/contact.htm
    More then likely Mr. Pass will still answer your questions. :D
    regards
    Dave
    Time is the best teacher. Unfortunately it kills all its students.
