eq hookup
tom t
tom t Posts: 543
what is the tyipical way to hook up a eq to a reciever?? eq has a set of line in/outs and tape in.outs. i know the tape in/outs replace the ones on the reciever. how to listen to tuner.
Post edited by tom t on
  • avguytx
    avguytx Posts: 1,628
    edited October 2007
    You tie it in thru the tape monitor loop just like you mentioned. When the tape monitor switch is "on" on the receiver, you select "tuner" and the tuner works. IIRC.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • tom t
    tom t Posts: 543
    edited October 2007
    thanks for the info dude. tom t
