Symphonic Reference Stereo Stack
JimBRICK
http://www.sunfire.com/Symphonic_Reference.htm
Anyone have hands on experience with this pair? If I end up buying the B&W 683's, this is what I want to use with them.
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Under construction
Post edited by JimBRICK on
Very nice Sunfire combo. 250 per ch @ 8ohm and 500 per ch @ 4 ohms. Trigger out to boot. Sweet.
engtazengtaz
Look back at some Mulveling's posts regarding his system.
http://www.polkaudio.com/forums/showthread.php?t=50174
He had that Sunfire amp, but then moved over to Parasound Halo series and was much happier. The Sunfires make the wattage, but do not have the high current capability that is needed for some speakers. -
billbillw,
thanks for the info.
engtazengtaz
None with that pair, but my friend has a Lightstar Preamp and amp.http://www.sunfire.com/Symphonic_Reference.htm
Loves it, a little dark sounding, but transparent and smooth.
