enough power?
mailman23
mailman23 Posts: 93
edited October 2007 in Speakers
Is there a a/v receiver out there that will do a decent job of running a pair of lsi 15's. Will the onkyo 805 or yamaha 2700 do it. Money is an issue and I can't afford a separate amp right now.
Post edited by mailman23 on
  • danger boy
    danger boy Posts: 15,722
    edited October 2007
    some receiver's will power the LSi series ok.. not great.. and the receiver may get very hot, or keep shutting down so it doesn't get toasted. IF you don't plan on listening to your LSi's at high volume levels, you should be ok.
    As you've probably read already.. of course a external amp is best to power those speakers. Even a lower wattage external amp can do wonders for those speakers.
    If your budget doesn't allow for an amp, then maybe consider going with other Polk speakers.. the RTiA series perhaps?
    PolkFest 2012, who's going>?
  • mailman23
    mailman23 Posts: 93
    edited October 2007
    Well I was considering rocket 850's, which have the vifa tweeter and are 8 ohms and easier to drive. The wife likes the way the 850's look and the way the lsi's look. I was trying to stay loyal to polk but I don't know if my budget will allow. I can't get everything at once.
  • McLoki
    McLoki Posts: 5,231
    edited October 2007
    NAD should do a decent job of it while staying in your budget. (provided you are willing to purchase used)
    Michael
  • engtaz
    engtaz Posts: 7,664
    edited October 2007
    Does your current receiver have pre amp outs?
    engtaz
  • read-alot
    read-alot Posts: 812
    edited October 2007
    mailman23 wrote: »
    I think my suggestion of a B&K receiver will be ruled out reading this mailman, but I've seen them on the used market pretty reasonable here lately though.
    B&K will drive the 4 ohm loads no problem.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • dkg999
    dkg999 Posts: 5,647
    edited October 2007
    I would look for a used B&K AVR 305. They are solid, will drive the Lsi's, and are a generation back in the product line and seem to sell at pretty reasonable prices.
    DKG999
  • Face
    Face Posts: 14,340
    edited October 2007
    How about Outlaw's 2ch. receiver?
  • MSALLA
    MSALLA Posts: 1,602
    edited October 2007
    Are you running a full 5.1 Lsi set-up or just a set of 15's? If it is just the 2 15's, the 805 or the 2700 will be ok. Some of the others like th NAD or B&K talked about will sound better. All talked about will have pre-outs so you could always add an amp later for an upgrade.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • mailman23
    mailman23 Posts: 93
    edited October 2007
    My current receiver does not have pre outs, so I'm screwed there. I do plan on running a full 5.1 setup. I looked up the b&k and found one for about $900. Will this power a 5.1 of lsi's for the time being? The onkyo and yamaha have hdmi switching, but if the b&k is superior I could live without that. Also, no response about the rocket 850's. They are on sale right now for $999 plus shipping. Do the Lsi's really rock or what?
  • dkg999
    dkg999 Posts: 5,647
    edited October 2007
    The Rocket's seem to get good reviews, and I believe we have at least a couple of members with them. I have only heard one set of Rockets, don't remember which ones, but they were impressive. Didn't win me over, but they weren't bad at all. The B&K receivers will run a 5.1 LSi system, at reasonable volumes, just make sure you have plenty of air space around the AVR. The B&K AVR's are pretty much separates in a single chassis, and have great pre/processors and great amp sections, but are a little shy on the bells & whistles.
    DKG999
  • mailman23
    mailman23 Posts: 93
    edited October 2007
    the rockets and the lsi both use the vifa tweeter, correct?
  • mailman23
    mailman23 Posts: 93
    edited October 2007
    you say that the rockets didn't win you over. Did the Lsi's win you over. How do the rockets sound in comparison? does anyone know? I'm nervous to buy speakers I haven't heard. I can listen to Lsi at a local audio store.
  • MSALLA
    MSALLA Posts: 1,602
    edited October 2007
    I don't like to buy anything I can't hear first. I did once and got burnt for doing it.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • dkg999
    dkg999 Posts: 5,647
    edited October 2007
    I've never heard the Rockets and LSi in a direct comparison. I do remember that the Rockets I heard didn't have the smoothest x-over in them, I could hear some separation in the drivers. I also wasn't impressed with the soundstage, although that could of been the room/set-up. I believe the Rockets have a return policy so you can audition them. With the comments the AV123/Rockets products get, I think you are pretty safe in giving them a try.
    I personally like the LSi line for HT. I wasn't, and still am not, impressed so much with them for music or 2 ch use. But I am very impressed using them for HT. You can't go wrong with LSi's in a combined HT/music system.
    DKG999
