Monitor 10 Tweeter
dyerstraits
I just purchased a pair of Monitor 10's. The tweeter doesn't work in one speaker. The model # is SL2000. Is this the correct tweeter? I thought is was supposed to be SL2500. Both tweeters are the same model.
Should i replace just the one tweeter, or should i buy a pair? And which model should i use?
mike
mike
Post edited by dyerstraits on
did you check for a fuse?
Also pull the tweeter out and check it with a multi meter.
Welcome to Club Polk
Ben -
no i did not check for a fuse, but a took the tweeter from the other speaker, and it works in the cab. with the bad tweeter.
Thanks,
mike -
My 10b's that I bought new have SL2000's.My equipment sig felt inadequate and deleted itself.
Monitor 10's were produced with several flavors of tweeters. Can you post a photo of your speaker sans grille and/or of the crossover?
www.polksda.com has pdf's of the old brochures.
