Speaker subwoofer too close to wall?
Tried to use search function but couldnt find an answer ....
In my setup I have the subwoofer portion of the LSi25 facing the wall, only 7-8 inches from the wall. Will this be a problem? or could I put it even closer to the wall to get the other LSi away from the dining room entrance a bit more (makes me nervous that some nut running into the living room will clip the speaker). My sig. is linked to my showcase to give a sense on placement.
Thanks ahead of time ....
I have many questions but will post them one at a time
Zsolt
Zsolt
Post edited by zx_toth on
I'd say 7" - 8" is way too close from the wall. Probably sounds boomy as hell. You're gonna hafta spend lots of time fooling around with placement to find the best spot for them.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I'd say 7" - 8" is way too close from the wall. Probably sounds boomy as hell. .
I guess I knew it but didnt want to believe it :rolleyes: Not much I can do in the room that Im in, as I look around and see that there is no better place ... since I just bought the home I cant say "Well next time I move" as that wont be any time soon. Ill tinker around with the settings and see if I can minimize some of that boom off the right wall.
Thanks.
Zsolt -
The PSW1000 manual says the driver should be at least 6" from the wall....so you are meeting that requirement. You might give Polk customer service a call and see what they say.B&W 804s mains
B&W HTM4 center
Polk PSW 1000 sub
Outlaw 990 Pre Amp
Anthem MCA 30 Amp
Monitor Radius 180 surrounds
Audiosource Stereo Amp for surrounds
Denon 2910 Universal DVD/SACD Player
Comcast DVR
Pioneer Elite 42" Plasma 940 HD
Harmony Universal Remote
Blue Jeans interconnects and biwires
Itunes Air Express -
Try flipping the left speaker to the right side and have the woofers face in. Russman gave me this tip back when I had my 15s and it helped immensely.
SolidSqual wrote: »Try flipping the left speaker to the right side and have the woofers face in. Russman gave me this tip back when I had my 15s and it helped immensely.
+1...Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
I will definately give them a call on Monday to see what they reccommend in this situation. In the interim I have turned down the subwoofer volume to 1/4 to calm down the effect. It seems more tamed now but still we seek some suggestions.
Thanks.
Zsolt -
Would that not cause a similar scenario? That is me having the subwoofer grill right against my TV stand, except than Ill have both against a surface. I am all for giving it a try if it improves the sound ... even if moving those 95 lb speaks is such a pain in the @rse
Zsolt
