balanced or unbalanced
Dave38
Dave38 Posts: 101
I'm wondering if there is an advantage to hooking up balanced connections from pre/pro to amp over using the un-balanced RCA connections. Thanks.
Post edited by Dave38 on
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited October 2007
    mainly noise rejection. If you have a problem with noise with rca's, or have a really long run use the balanced conections
    heiney9 Posts: 25,531
    edited October 2007
    Covered hundreds of times in 100's of threads. Please get your search on and you'll be amazed at the info already available
  • Dave38
    Dave38 Posts: 101
    edited October 2007
    heiney9 wrote: »
    OK, thanks.
    edited October 2007
    Dave38 wrote: »
    OK, thanks.
    Didn't mean to be so flippant. If you scroll to the bottom of your screen (similar threads) while in this thread there are about 5 threads which might be what you ae looking for.
  • Dave38
    Dave38 Posts: 101
    edited October 2007
    heiney9 wrote: »
    Oh, I know. I didn't think you were. I will use the search feature in the future.
  • janmike
    janmike Posts: 6,146
    edited October 2007
    To me it really depends on the devices. Some do and some do not.
    Michael ;)
    NORTH of 60°
